[AG-DEV] AccessGrid3.interfaces??
Christoph Willing
willing at itee.uq.edu.au
Fri Jan 13 13:51:43 CST 2006
On 14/01/2006, at 3:13 AM, Susanne Lefvert wrote:
> Hello Chris,
> You are right, setup.py was missing code for generating interfaces. We
> have added that to cvs now and are also working on other parts of
> packaging for 3.0. The code for packaging in cvs will be changing
> over the
> next few days while we are getting everything worked out.
Susanne,
Thanks, that fixed it.
chris
> On Fri, 13 Jan 2006, Christoph Willing wrote:
>> On 13/01/2006, at 7:41 PM, Michael Braitmaier wrote:
>>> You should get the interfaces directory when running CVSSetup.py -a
>>> from the tools directory.
>>> This way the wsdl files from the wsdl directory are compiled to
>>> python files which are put into a directory called interfaces.
>>> These files provide the "stubs" for the webservices, as far as I
>>> understood it.
>> Thanks Michael. If that is the case, then this step (or something
>> similar that produces the interfaces directory) is missing from
>> AccessGrid/setup.py and needs to be added. I gather running
>> CVSSetup.py is necessary to run live from CVS, but its never been
>> part of the packaging procedure so far.
>> chris
>>> Christoph Willing schrieb:
>>>> I'm just starting to look at building AccessGrid/packaging/
>>>> BuildSnapshot.py
>>>> The first problem is when it runs AccessGrid/setup.py, where there
>>>> is a list named 'packages' containing an element
>>>> AccessGrid3.interfaces. All the elements in that list have a
>>>> corresponding directory with the same name, however there is no
>>>> interfaces directory.
>>>> Am I missing an interfaces directory, or can I safely remove
>>>> AccessGrid3.interfaces from the list?
>>>> chris
>>>> Christoph Willing +61 7 3365 8350
>>>> QPSF Access Grid Manager
>>>> University of Queensland
>>> Dipl.-Inf. Michael Braitmaier
>>> HLRS - Visualization / Video Conferencing
>>> University of Stuttgart
>>> Germany
>>> Phone: ++49 711 685 5996
>>> Fax : ++49 711 682 357
>>> Website: http://www.hlrs.de/people/braitmaier/
