[AG-DEV] AG3 VenueManagement can't connect
Todd Zimmerman
toddz at sfu.ca
Wed Feb 22 12:07:03 CST 2006
I'm running the server from CVS installed yesterday and I tested connecting locally and remotely
from a FC4 box running the latest code from Doug's site (installed yesterday also).
I've attached the VenueManagement.log from both the server (local) and a client (remote).
I will nuke my cvs AccessGrid install and try it again to ensure that the server isn't in an odd
state... and like I mentioned, I had to make a couple of changes on the server to get it to run - so
a reinstall is probably worth it to ensure a clean installation.
Todd
Thomas D. Uram wrote:
> I believe it was resolved before beta1. Which code are you running?
> Can you provide
> more of VenueManagement.log?
> On 2/22/06 1:31 AM, Todd Zimmerman wrote:
>> Was this problem ever resolved??
>> I'm running into the same issue - trying to connect with a valid
>> service certificate from either the
>> local machine or a remote machine.
>> VenueManagement.log reports:
>> sslerror: (1, 'error:14094418:SSL routines:SSL3_READ_BYTES:tlsv1 alert
>> unknown ca'
>> The server is running on a RHEL4 box so there may be some oddities -
>> but the server seems to be
>> stable and will accept connections.
>> Any info would help - thx!
>> Todd
>>> Ok, I haven't been able to reproduce the problem, but Eric has seen this
>>> problem.
>>> We'll get back to you today with a fix.
>>> Tom
>>> On 1/21/06 3:07 AM, Christoph Willing wrote:
>>>> On 21/01/2006, at 6:53 AM, Thomas D. Uram wrote:
>>>>> Chris:
>>>>> This line occurs repeatedly:
>>>>> alert unknown ca')
>>>>> Do you have the appropriate CA certs in the cert repository?
>>>> Tom,
>>>> I have:
>>>> ag at v2:~$ ls -l /etc/AccessGrid3/Config/CAcertificates/
>>>> total 32
>>>> -rw-r--r-- 1 ag ag 1436 2004-04-20 08:00 1c3f2ca8.0
>>>> -rw-r--r-- 1 ag ag 2276 2004-05-07 04:51 1c3f2ca8.signing_policy
>>>> -rw-r--r-- 1 ag ag 904 2004-03-26 00:25 45cc9e80.0
>>>> -rw-r--r-- 1 ag ag 1334 2004-03-26 00:25 45cc9e80.signing_policy
>>>> -rw-r--r-- 1 ag ag 1448 2004-04-20 08:00 d1b603c3.0
>>>> -rw-r--r-- 1 ag ag 2263 2004-03-26 00:25 d1b603c3.signing_policy
>>>> -rw-r--r-- 1 ag ag 1334 2004-09-06 15:26 f18fa857.0
>>>> -rw-r--r-- 1 ag ag 571 2004-09-06 15:26 f18fa857.signing_policy
>>>>> I'm ignoring the 'connection refused' errors, because I expect
>>>>> either the server wasn't
>>>>> running, or was running on a different network interface.
>>>> The venue server was running; there's only one network interface on
>>>> the machine.
>>>> chris
>>>>> On 1/20/06 2:37 PM, Christoph Willing wrote:
>>>>>> On 21/01/2006, at 3:03 AM, Thomas D. Uram wrote:
>>>>>>> Is there mention of the default certificate in VenueManagement.log?
>>>>>>> If details there aren't clear, I'd sure be interested to see the
>>>>>>> log.
>>>>>> Tom,
>>>>>> A log of yesterday's attempts is attached. It includes attempts
>>>>>> with server running secure mode then insecure mode, although I
>>>>>> don't know if thats evident from the log. It also shows the
>>>>>> different server names used (localhost & fqdn).
>>>>>> The default certificate is mentioned a few times (at each start up
>>>>>> I guess). Since VenueServer and VenueManagement are running on the
>>>>>> same machine, each is using the same default cert, which mostly
>>>>>> happens to be a server certificiate, although you'll see near the
>>>>>> end that I also tried using an Anonymous User cert too.
>>>>>> chris
>>>>>>> On 1/19/06 10:25 PM, Christoph Willing wrote:
>>>>>>>> On 20/01/2006, at 2:01 PM, Thomas D. Uram wrote:
>>>>>>>>> Is your default certificate an identity certificate (i.e.,
>>>>>>>>> does it require a passphrase?).
>>>>>>>>> That's not being handled currently. If so, try using a
>>>>>>>>> service certificate instead.
>>>>>>>>> If not, something's wrong.
>>>>>>>> Tom,
>>>>>>>> Its a VenueServer certificate, borrowed from another machine,
>>>>>>>> and same result using an anonymous certificate.
>>>>>>>> ag at v2:~$ certmgr.py
>>>>>>>> (ID mode) > list
>>>>>>>> 1. (Default) /O=Access Grid/OU=agdev-ca.mcs.anl.gov/
>>>>>>>> CN=VenueServer/ seivers.vislab.uq.edu.au
>>>>>>>> 2. /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
>>>>>>>> Anonymous Authority/CN=Anonymous User
>>>>>>>> 486c88f05354caa6e542b09b19cdee01
>>>>>>>> (ID mode) > show 1
>>>>>>>> Subject: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/
>>>>>>>> Issuer: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
>>>>>>>> Developers CA
>>>>>>>> Certificate version: 2
>>>>>>>> Serial number: 5778
>>>>>>>> Not valid before: 03/18/05 01:41:35
>>>>>>>> Not valid after: 03/18/06 01:41:35
>>>>>>>> MD5 Fingerprint: 2A:81:9C:98:C2:76:09:1F:6C:E9:3E:47:B7:99:65:65
>>>>>>>> Certificate location: /home/ag/.AccessGrid3/Config/certRepo/
>>>>>>>> certificates/9c833de531fe7da7cff5bbfeaaf770fc/
>>>>>>>> 1c291311d25c9e1f2a79b98047ad6fec/cert.pem
>>>>>>>> Private key location: /home/ag/.AccessGrid3/Config/certRepo/
>>>>>>>> privatekeys/2f30fa4ccf0c09b08e4b9050829bc33b.pem
>>>>>>>>> On 1/19/06 7:30 PM, Christoph Willing wrote:
>>>>>>>>>> Working with a packaged AG3, I can run the VenueServer and
>>>>>>>>>> connect to it with a VenueClient. However I can't connect
>>>>>>>>>> to it with the VenueManagement tool. Trying to connect (from
>>>>>>>>>> same machine) with:
>>>>>>>>>> https://localhost/VenueServer
>>>>>>>>>> or https://v2.vislab.uq.edu.au/VenueServer
>>>>>>>>>> both immediately result in a "Unable To Connect" popup msg
>>>>>>>>>> box saying:
>>>>>>>>>> You were unable to connect to the venue server at:
>>>>>>>>>> https://v2.vislab.uq.edu.au/VenueServer.
>>>>>>>>>> The VenueServer.log doesn't mention anything about a
>>>>>>>>>> connection attempt in such cases.
>>>>>>>>>> If I then add a :8000 to the url, the following error is
>>>>>>>>>> added to VenueServer.log:
>>>>>>>>>> 01/20/06 11:27:29 -1273504848 Hosting ServiceContainer.py:
>>>>>>>>>> 146 ERROR None
>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>> File "/usr/lib/python2.4/site-packages/M2Crypto/SSL/
>>>>>>>>>> SSLServer.py", line 29, in handle_request
>>>>>>>>>> request, client_address = self.get_request()
>>>>>>>>>> File "/usr/lib/python2.4/SocketServer.py", line 373, in
>>>>>>>>>> get_request
>>>>>>>>>> return self.socket.accept()
>>>>>>>>>> Connection.py", line 114, in accept
>>>>>>>>>> ssl.accept_ssl()
>>>>>>>>>> Connection.py", line 103, in accept_ssl
>>>>>>>>>> return m2.ssl_accept(self.ssl)
>>>>>>>>>> SSLError: no certificate returned
>>>> Christoph Willing +61 7 3365 8350
>>>> QPSF Access Grid Manager
>>>> University of Queensland
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20060222/a2655b90/attachment.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20060222/a2655b90/attachment-0001.bin>
