[AG-DEV] Custom Node Service Enabling/Disabling Problem
Michael Braitmaier
braitmaier at hlrs.de
Fri Aug 11 04:00:20 CDT 2006
Hi Todd!
Looking more into your debug file I can see, that AccessGrid obviously
uses AccessGrid code from different versions like in the following
extract of the logfile:
Traceback (most recent call last):
File "/usr/lib/python2.4/site-packages/AccessGrid/AGNodeService.py",
line 708, in __SendStreamsToService
if c.matches(cap):
File
"/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/Descriptions.py",
line 314, in matches
if (str(self.type) != str(capability.type) or
TypeError: int() argument must be a string or a number
The file AGNodeService.py seems to come from
while the file Descriptions.py is coming from
python2.4/site-packages/accessGrid3/AccessGrid
Possibly there is a mix of AG2.4 and AG3.0 code?
Michael
Michael Braitmaier schrieb:
> Hi Todd!
> In fact I think the problem narrows down to the follwing line in the log:
> File
> Apprently the two values are not compareable in some way.
> I assume you use the modified code which I sent you.
> The problem could possibly be introduced by my modifications.
> It would be helpful to see what values are contained in
> self.type and
> capability.type
> Possibly one of the variables contain a "None"-value (however this
> value got there), which would lead to the given error message.
> Refering to Brians assumption on the service not being able to handle
> the stream:
> In fact at the end the
> raise SetStreamException(failedSends)
> is just a propagation of the exception in the Capability's match
> function.
> So I don't think that this caused by the service not being able to
> habndle the stream.
> Todd:
> If you can tell me what values are contained in the variables, I can
> help you find the problem and even update my sources eliminating the bug.
> Michael
> Todd Zimmerman schrieb:
>> Sorry for the spam - but just realized that it looks like this issue
>> was identified and a fix was
>> made by Michael Braitmaier.
>> The problem was the default None values of rate and code in the
>> Capabilities class. Michael made
>> the default value of codec = "" and rate = 0 - which allows the match
>> function to properly check for
>> matches. This seems to alleviate the issue - but does it raise any
>> other problems??
>> Cheers,
>> Todd
>> Todd Zimmerman wrote:
>>> one more time WITH the logfiles... ;-)
>>>> Oh... I sent them to ag-dev yesterday...
>>>> Here's a resend.
>>>> Looks like the relevent section is:
>>>> 08/09/2006 11:15:40 AM -1208600896 NodeManagementUIClasses
>>>> NodeManagementUIClasses.py:1043 ERROR
>>>> Error enabling service
>>>> File
>>>> "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/NodeManagementUIClasses.py",
>>>> line
>>>> 1037, in EnableService
>>>> self.nodeServiceHandle.SetServiceEnabled(service.uri, 1)
>>>> File
>>>> line 278, in SetServiceEnabled
>>>> self.__SendStreamsToService( serviceUri )
>>>> File
>>>> line 723, in
>>>> SetStreamException: Error updating [producer, debug, None, None,
>>>> None, 1, consumer, debug, None,
>>>> None, None, 1]
>>>> Cheers,
>>>> Todd
>>>> Thomas D. Uram wrote:
>>>>> Any details from logfile?
>>>>>>> Also, which platform?
>>>>>> Fedora Core 5 running AccessGrid-3.0.2-0.1.20060727cvs
>>>>>> Cheers,
>>>>>> Todd
>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Config.py:559 DEBUG
>>>>>> System hostname of floyd.irmacs.sfu.ca is valid
>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:111 DEBUG
>>>>>> Initializing AG Toolkit version 3.0.2
>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:112 INFO
>>>>>> Command and arguments:
>>>>>> ['/data/tz/.AccessGrid3/local_services/DebugService/DebugService.py',
>>>>>> '--port', '64864', '--serviceManagerUri',
>>>>>> 'http://floyd.irmacs.sfu.ca:11000/ServiceManager', '--token',
>>>>>> '8e3a358332f86536e976086dbec2c57f']
>>>>>> 08/09/06 11:15:07 -1208117568 VenueClient Preferences.py:180
>>>>>> DEBUG Preferences.LoadPreferences: open file
>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:161 INFO
>>>>>> Logfile Name: DebugService.log
>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:650 INFO
>>>>>> Service init: have profile None
>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:675 INFO
>>>>>> Service Initialization Complete.
>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit AGService.py:363 INFO
>>>>>> Starting Service URI:
>>>>>> http://floyd.irmacs.sfu.ca:64864/Services/DebugService.8e3a3583333a6536e9540206adb5e731
>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit AGService.py:373 DEBUG
>>>>>> Registering with service manager;
>>>>>> url=http://floyd.irmacs.sfu.ca:11000/ServiceManager
>>>>>> 08/09/06 11:15:07 -1225385056 Toolkit DebugService.py:68
>>>>>> INFO SetIdentity method called
>>>>>> 08/09/06 11:15:12 -1225385056 Toolkit AGService.py:214 INFO
>>>>>> AGService.SetEnabled : enabled = 0
>>>>>> 08/09/06 11:15:12 -1225385056 Toolkit AGService.py:220 INFO
>>>>>> Stopping service
>>>>>> 08/09/06 11:15:12 -1225385056 Toolkit DebugService.py:50
>>>>>> INFO Stop method called
>>>>>> 08/09/06 11:15:14 -1225385056 Toolkit AGService.py:214 INFO
>>>>>> AGService.SetEnabled : enabled = 1
>>>>>> 08/09/06 11:15:15 -1225385056 Toolkit AGService.py:214 INFO
>>>>>> 08/09/06 11:15:15 -1225385056 Toolkit AGService.py:220 INFO
>>>>>> Stopping service
>>>>>> 08/09/06 11:15:15 -1225385056 Toolkit DebugService.py:50
>>>>>> 08/09/06 11:15:17 -1225385056 Toolkit AGService.py:214 INFO
>>>>>> 08/09/06 11:15:23 -1225385056 Toolkit DebugService.py:50
>>>>>> 08/09/06 11:15:30 -1225385056 Toolkit AGService.py:214 INFO
>>>>>> 08/09/06 11:15:30 -1225385056 Toolkit AGService.py:220 INFO
>>>>>> Stopping service
>>>>>> 08/09/06 11:15:30 -1225385056 Toolkit DebugService.py:50
>>>>>> 08/09/06 11:15:38 -1225385056 Toolkit AGService.py:214 INFO
>>>>>> 08/09/06 11:15:38 -1225385056 Toolkit AGService.py:220 INFO
>>>>>> Stopping service
>>>>>> 08/09/06 11:15:38 -1225385056 Toolkit DebugService.py:50
>>>>>> 08/09/06 11:15:55 -1225385056 Toolkit DebugService.py:50
>>>>>> 08/09/06 11:15:58 -1225385056 Toolkit AGService.py:238 INFO
>>>>>> Shut service down
>>>>>> 08/09/06 11:15:58 -1225385056 Toolkit DebugService.py:50
>>>>>> 08/09/06 11:15:58 -1208117568 Toolkit AGService.py:238 INFO
>>>>>> Shut service down
>>>>>> 08/09/06 11:15:58 -1208117568 Toolkit DebugService.py:50
>>>>>> 08/09/2006 11:14:55 AM -1208600896 VenueClientController
>>>>>> VenueClientController.py:432 DEBUG VenueClientController calling
>>>>>> Venue.EnterVenue
>>>>>> VenueClient.py:1015 DEBUG EnterVenue;
>>>>>> url=https://venueserver2.westgrid.ca:8000/Venues/default
>>>>>> 08/09/2006 11:14:55 AM -1208600896 NodeService
>>>>>> AGNodeService.py:658 INFO NodeService.GetCapabilities
>>>>>> AGNodeService.py:257 INFO NodeService.GetServices
>>>>>> 08/09/2006 11:14:55 AM -1225692256 ServiceManager
>>>>>> AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>>> VenueClient.py:1049 DEBUG calling __EnterVenue
>>>>>> VenueClient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
>>>>>> VenueClient.py:808 DEBUG after Venue.Enter
>>>>>> VenueClient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
>>>>>> 08/09/2006 11:14:56 AM -1208600896 VenueClient
>>>>>> VenueClient.py:812 DEBUG EnterVenue: done Venue.getstate
>>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClient
>>>>>> VenueClient.py:835 DEBUG Setting isInVenue flag.
>>>>>> VenueClient.py:1051 DEBUG after __EnterVenue
>>>>>> VenueClientUI.py:2577 DEBUG bin.VenueClient::EnterVenue: Enter
>>>>>> venue with url: https://venueserver2.westgrid.ca:8000/Venues/default
>>>>>> VenueClientUI.py:2690 DEBUG Entered venue
>>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClientController
>>>>>> VenueClientController.py:434 DEBUG VenueClientController after
>>>>>> Venue.EnterVenue
>>>>>> 08/09/2006 11:14:57 AM -1225692256 VenueClient
>>>>>> VenueClient.py:450 DEBUG Calling Heartbeat, time now: 1155147297
>>>>>> VenueClientUI.py:3324 DEBUG ContentListPanel.AddParticipant::
>>>>>> AddParticipant Todd Zimmerman (called from
>>>>>> ('/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/_core.py',
>>>>>> 13535, '<lambda>', 'lambda event: event.callable(*event.args,
>>>>>> **event.kw) )'))
>>>>>> VenueClient.py:474 DEBUG Next Heartbeat needed within 36s
>>>>>> 08/09/2006 11:14:57 AM -1225692256 JabberClient
>>>>>> JabberClient.py:33 INFO Connecting to Jabber Server
>>>>>> 'jabber.mcs.anl.gov' ...
>>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:100 DEBUG
>>>>>> RECV: <?xml version='1.0'?><stream:stream
>>>>>> xmlns:stream='http://etherx.jabber.org/streams' id='44DA2621'
>>>>>> xmlns='jabber:client' from='jabber.mcs.anl.gov'>
>>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize
>>>>>> serialize.py:65 DEBUG feed parser initialized
>>>>>> serialize.py:72 DEBUG start
>>>>>> <{http://etherx.jabber.org/streams}stream> level=0
>>>>>> JabberClient.py:168 INFO Registering the user
>>>>>> '8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' in
>>>>>> jabber server ...
>>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:122 DEBUG
>>>>>> SEND: <iq type="get"><query xmlns="jabber:iq:register" /></iq>
>>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:161 DEBUG
>>>>>> RECV: <iq type='result'><query
>>>>>> xmlns='jabber:iq:register'><password/><password/>
>>>>>> <instructions>Choose a username and password to register
>>>>>> with this server.</instructions>
>>>>>> <name/>
>>>>>> <email/>
>>>>>> <username/></query></iq>
>>>>>> serialize.py:72 DEBUG start <{jabber:client}iq> level=1
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}query> level=2
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}password> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}password> level=3
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}instructions>
>>>>>> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}instructions> level=3
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}name> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}name> level=3
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}email> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}email> level=3
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}username> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}username> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}query> level=2
>>>>>> serialize.py:86 DEBUG end <{jabber:client}iq> level=1
>>>>>> SEND: <iq type="set"><query
>>>>>> xmlns="jabber:iq:register"><username>8180087163ff65364de2ad59cc6ba1e9</username><password>8180087163ff65364de2ad59cc6ba1e9</password></query></iq>
>>>>>> 08/09/2006 11:14:58 AM -1225692256 bajjer.io io.py:161 DEBUG
>>>>>> RECV: <iq type='result'/>
>>>>>> 08/09/2006 11:14:58 AM -1225692256 bajjer.serialize
>>>>>> 08/09/2006 11:14:58 AM -1208600896 GroupMsgClient
>>>>>> GroupMsgClient.py:112 INFO Connected. Connection ID:
>>>>>> 08/09/2006 11:14:58 AM -1208600896 EventClient
>>>>>> InsecureVenueEventClient.py:60 INFO BaseVenueEventClient made
>>>>>> connection.
>>>>>> 08/09/2006 11:14:59 AM -1225692256 JabberClient
>>>>>> JabberClient.py:177 INFO Attempting to log in as
>>>>>> 8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default ...
>>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:122 DEBUG
>>>>>> xmlns="jabber:iq:auth"><username>8180087163ff65364de2ad59cc6ba1e9</username></query></iq>
>>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:161 DEBUG
>>>>>> xmlns='jabber:iq:auth'><username>8180087163ff65364de2ad59cc6ba1e9</username><digest/><password/><resource/></query></iq>
>>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}query> level=2
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}username> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}username> level=3
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}digest> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}digest> level=3
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}password> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}password> level=3
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}resource> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}resource> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}query> level=2
>>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.stream
>>>>>> stream.py:326 DEBUG Recv: <gov.lbl.dsd.bajjer.stanza.Iq object at
>>>>>> 0xb46c2dcc>
>>>>>> stream.py:342 DEBUG performing 'digest' authentication
>>>>>> xmlns="jabber:iq:auth"><resource>default</resource><username>8180087163ff65364de2ad59cc6ba1e9</username><digest>cf40bb3969d2778217e87b01c0948d0cf96ec019</digest></query></iq>
>>>>>> RECV: <iq type='result' id='pthsock_client_auth_ID'/>
>>>>>> stream.py:351 DEBUG Authorization succeeded
>>>>>> SEND: <iq from="8180087163ff65364de2ad59cc6ba1e9"
>>>>>> type="get"><query xmlns="jabber:iq:roster" /></iq>
>>>>>> RECV: <iq
>>>>>> from='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default'
>>>>>> type='result'><query xmlns='jabber:iq:roster'/></iq>
>>>>>> serialize.py:72 DEBUG start <{jabber:iq:roster}query> level=2
>>>>>> serialize.py:86 DEBUG end <{jabber:iq:roster}query> level=2
>>>>>> SEND: <presence />
>>>>>> JabberClient.py:73 DEBUG Sending the presence to
>>>>>> 'Main-Lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>> Zimmerman' of type 'available'...
>>>>>> SEND: <presence
>>>>>> to="Main-Lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>> Zimmerman" type="available"><x /></presence>
>>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient
>>>>>> VenueClient.py:959 INFO VenueClient.StartBeacon: Address
>>>>>> 233.59.192.88/49482
>>>>>> 08/09/2006 11:14:59 AM -1225692256 RTPBeacon RTPBeacon.py:278
>>>>>> DEBUG Called Start.
>>>>>> VenueClient.py:1231 INFO In UpdateStream: transport=unicast
>>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.io io.py:161 DEBUG
>>>>>> RECV: <message from='jabber.mcs.anl.gov'
>>>>>> to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov'>
>>>>>> <subject>Welcome!</subject>
>>>>>> <body>Welcome to the Access Grid Jabber server @
>>>>>> jabber.mcs.anl.gov -- we hope you enjoy this service! For
>>>>>> information about how to use Jabber, visit the Jabber User's
>>>>>> Guide at http://jabbermanual.jabberstudio.org/</body>
>>>>>> <x xmlns='jabber:x:delay'
>>>>>> from='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov'
>>>>>> stamp='20060809T18:14:57'>Offline Storage</x></message>
>>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize
>>>>>> serialize.py:72 DEBUG start <{jabber:client}message> level=1
>>>>>> serialize.py:72 DEBUG start <{jabber:client}subject> level=2
>>>>>> serialize.py:86 DEBUG end <{jabber:client}subject> level=2
>>>>>> serialize.py:72 DEBUG start <{jabber:client}body> level=2
>>>>>> serialize.py:86 DEBUG end <{jabber:client}body> level=2
>>>>>> serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
>>>>>> serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
>>>>>> serialize.py:86 DEBUG end <{jabber:client}message> level=1
>>>>>> 08/09/2006 11:14:59 AM -1345344608 JabberClient
>>>>>> JabberClient.py:133 DEBUG jabber.mcs.anl.go: Welcome to the
>>>>>> Access Grid Jabber server @ jabber.mcs.anl.gov -- we hope you
>>>>>> enjoy this service! For information about how to use Jabber,
>>>>>> visit the Jabber User's Guide at
>>>>>> VenueClient.py:1260 DEBUG Got location from bridge: unicast
>>>>>> milton.mcs.anl.gov 53768
>>>>>> RECV: <presence
>>>>>> to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default'
>>>>>> from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>> Zimmerman'><x/><x
>>>>>> xmlns='http://jabber.org/protocol/muc#user'><item
>>>>>> affiliation='none' role='participant'/></x></presence>
>>>>>> serialize.py:72 DEBUG start <{jabber:client}presence> level=1
>>>>>> serialize.py:72 DEBUG start <{jabber:client}x> level=2
>>>>>> serialize.py:86 DEBUG end <{jabber:client}x> level=2
>>>>>> <{http://jabber.org/protocol/muc#user}x> level=2
>>>>>> <{http://jabber.org/protocol/muc#user}item> level=3
>>>>>> serialize.py:86 DEBUG end <{jabber:client}presence> level=1
>>>>>> JabberClient.py:145 DEBUG
>>>>>> Zimmerman is available (None / None)
>>>>>> 08/09/2006 11:14:59 AM -1345344608 VenueClient
>>>>>> VenueClientUI.py:2299 DEBUG add user: Todd Zimmerman
>>>>>> RECV: <message type='groupchat'
>>>>>> from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>main-lobby(venueserver2.westgrid.ca)</body></message>
>>>>>> main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.go:
>>>>>> from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>This
>>>>>> room supports the MUC protocol.</body></message>
>>>>>> milton.mcs.anl.gov 52884
>>>>>> to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default'><body>Todd
>>>>>> Zimmerman has joined this session</body></message>
>>>>>> main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.go: This
>>>>>> main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.go: Todd
>>>>>> milton.mcs.anl.gov 52844
>>>>>> 08/09/2006 11:14:59 AM -1225692256 RTPBeacon RTPBeacon.py:296
>>>>>> DEBUG Called Stop.
>>>>>> VenueClient.py:951 INFO Beacon being reconfigured, stopping
>>>>>> running beacon
>>>>>> DEBUG Called Stop.
>>>>>> milton.mcs.anl.gov/52844
>>>>>> DEBUG Called Start.
>>>>>> VenueClient.py:1190 DEBUG UpdateNodeService: Method
>>>>>> UpdateNodeService called
>>>>>> VenueClient.py:1195 DEBUG Setting node service streams
>>>>>> 08/09/2006 11:14:59 AM -1225692256 NodeService
>>>>>> AGNodeService.py:328 INFO NodeService.SetStreams
>>>>>> 08/09/2006 11:14:59 AM -1387304032 ServiceManager
>>>>>> 08/09/2006 11:15:00 AM -1225692256 NodeService
>>>>>> AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>>> 08/09/2006 11:15:00 AM -1366324320 RTPBeacon RTPBeacon.py:289
>>>>>> INFO RTPBeacon.UpdateThread exiting
>>>>>> AGNodeService.py:699 DEBUG service capabilities: [consumer,
>>>>>> audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1, consumer,
>>>>>> audio, 8e3a358333096536dec30af9596ae5ae, L16, 8000, 1, consumer,
>>>>>> audio, 8e3a358333096536dec30af9596ae5ae, L8, 16000, 1, consumer,
>>>>>> audio, 8e3a358333096536dec30af9596ae5ae, L8, 8000, 1, consumer,
>>>>>> audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 16000, 1,
>>>>>> consumer, audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 8000, 1,
>>>>>> consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 16000, 1,
>>>>>> consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 8000, 1,
>>>>>> producer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1]
>>>>>> AGNodeService.py:713 INFO Sending stream (type=[consumer, audio,
>>>>>> 8180087163ff629be0bebd48a1912f0f, L16, 16000, 1, consumer, audio,
>>>>>> 8180087163ff629be0bebd48a1912f0f, L16, 8000, 1, consumer, audio,
>>>>>> 8180087163ff629be0bebd48a1912f0f, L8, 16000, 1, consumer, audio,
>>>>>> 8180087163ff629be0bebd48a1912f0f, L8, 8000, 1, consumer, audio,
>>>>>> 8180087163ff629be0bebd48a1912f0f, PCMU, 16000, 1, consumer,
>>>>>> audio, 8180087163ff629be0bebd48a1912f0f, PCMU, 8000, 1, consumer,
>>>>>> audio, 8180087163ff629be0bebd48a1912f0f, GSM, 16000, 1, consumer,
>>>>>> audio, 8180087163ff629be0bebd48a1912f0f, GSM, 8000, 1]) to
>>>>>> service:
>>>>>> http://floyd.irmacs.sfu.ca:56488/Services/AudioService.8e3a358333096536decfdc29e8e7216d
>>>>>> video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1,
>>>>>> producer, video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1]
>>>>>> AGNodeService.py:713 INFO Sending stream (type=[consumer, video,
>>>>>> 8180087163ff629be0bbbd489dcbd809, H261, 90000, 1]) to service:
>>>>>> http://floyd.irmacs.sfu.ca:62272/Services/VideoService.8e3a358333036536de95b64fe81b7c08
>>>>>> 08/09/2006 11:15:00 AM -1225692256 VenueClient
>>>>>> VenueClient.py:914 DEBUG Updating client profile cache.
>>>>>> 08/09/2006 11:15:00 AM -1208600896 VenueClient
>>>>>> VenueClientUI.py:1291 DEBUG VenueClientFrame.ManageNodeCB: open
>>>>>> node management
>>>>>> VenueClientUI.py:1292 DEBUG nodeservice url:
>>>>>> <AccessGrid.AGNodeService.AGNodeService instance at 0xb6f3518c>
>>>>>> 08/09/2006 11:15:00 AM -1208600896 NodeService
>>>>>> AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>>> 08/09/2006 11:15:00 AM -1225692256 ServiceManager
>>>>>> 08/09/2006 11:15:07 AM -1225692256 ServiceManager
>>>>>> AGServiceManager.py:102 INFO AGServiceManager.AddService
>>>>>> AGServiceManager.py:339 INFO Installed service version: 1.1,
>>>>>> package version: 1.1
>>>>>> AGServiceManager.py:374 DEBUG Executing service DebugService
>>>>>> AGServiceManager.py:406 INFO Running Service; options:
>>>>>> '--port', 64864, '--serviceManagerUri',
>>>>>> AGServiceManager.py:418 INFO Service registered:
>>>>>> 08/09/2006 11:15:07 AM -1208600896 NodeManagementUIClasses
>>>>>> NodeManagementUIClasses.py:1000 INFO No resources for service
>>>>>> 08/09/2006 11:15:07 AM -1208600896 VenueClient
>>>>>> VenueClientUI.py:1933 INFO OnNodeActivity: got action: add_service
>>>>>> 08/09/2006 11:15:07 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:12 AM -1208600896 NodeService
>>>>>> AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>>> 08/09/2006 11:15:12 AM -1225692256 ServiceManager
>>>>>> 08/09/2006 11:15:14 AM -1208600896 NodeManagementUIClasses
>>>>>> NodeManagementUIClasses.py:1036 DEBUG
>>>>>> NodeManagementClientFrame.EnableService: Enabling Service:
>>>>>> DebugService
>>>>>> 08/09/2006 11:15:14 AM -1208600896 NodeService
>>>>>> AGNodeService.py:699 DEBUG service capabilities: [producer,
>>>>>> debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>>> 08/09/2006 11:15:14 AM -1225692256 ServiceManager
>>>>>> 08/09/2006 11:15:15 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:15 AM -1225692256 ServiceManager
>>>>>> 08/09/2006 11:15:16 AM -1208600896 NodeManagementUIClasses
>>>>>> DebugService
>>>>>> 08/09/2006 11:15:17 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:17 AM -1225692256 ServiceManager
>>>>>> 08/09/2006 11:15:23 AM -1208600896 VenueClient
>>>>>> VenueClient.py:1132 INFO ExitVenue
>>>>>> VenueClient.py:1173 INFO ExitVenue: Stopping node services
>>>>>> 08/09/2006 11:15:23 AM -1208600896 NodeService
>>>>>> AGNodeService.py:301 INFO NodeService.StopServices
>>>>>> 08/09/2006 11:15:23 AM -1225692256 ServiceManager
>>>>>> AGServiceManager.py:225 INFO AGServiceManager.StopServices
>>>>>> 08/09/2006 11:15:24 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:24 AM -1225692256 ServiceManager
>>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient
>>>>>> VenueClient.py:1103 DEBUG ExitVenue: Stop event client obj
>>>>>> VenueClient.py:1105 DEBUG ExitVenue: Remove event client reference
>>>>>> VenueClient.py:1110 INFO ExitVenue: Stopping text client
>>>>>> 08/09/2006 11:15:25 AM -1208600896 JabberClient
>>>>>> Zimmerman' of type 'unavailable'...
>>>>>> 08/09/2006 11:15:25 AM -1208600896 bajjer.io io.py:122 DEBUG
>>>>>> SEND: <presence
>>>>>> Zimmerman" type="unavailable"><x /></presence>
>>>>>> 08/09/2006 11:15:25 AM -1208600896 RTPBeacon RTPBeacon.py:296
>>>>>> DEBUG Called Stop.
>>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClientController
>>>>>> Venue.EnterVenue
>>>>>> url=https://venueserver2.westgrid.ca:8000/Venues/8e3a35534ae01a166229939b5aed6d47
>>>>>> 08/09/2006 11:15:25 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:25 AM -1334854752 ServiceManager
>>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.io io.py:161 DEBUG
>>>>>> RECV: <presence
>>>>>> type='unavailable'
>>>>>> Zimmerman'><x/><x
>>>>>> affiliation='none' role='none'/></x></presence>
>>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize
>>>>>> 08/09/2006 11:15:25 AM -1345344608 JabberClient
>>>>>> JabberClient.py:148 DEBUG
>>>>>> Zimmerman is unavailable (None / None)
>>>>>> 08/09/2006 11:15:25 AM -1345344608 VenueClient
>>>>>> VenueClientUI.py:2313 DEBUG remove user: Todd Zimmerman
>>>>>> 08/09/2006 11:15:25 AM -1376814176 RTPBeacon RTPBeacon.py:289
>>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClient
>>>>>> venue with url:
>>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClientController
>>>>>> Venue.EnterVenue
>>>>>> 08/09/2006 11:15:26 AM -1376814176 VenueClient
>>>>>> VenueClient.py:450 DEBUG Calling Heartbeat, time now: 1155147326
>>>>>> VenueClientUI.py:3340 DEBUG ContentListPanel.RemoveParticipant:
>>>>>> Remove participant
>>>>>> **event.kw) )'))
>>>>>> 08/09/2006 11:15:27 AM -1376814176 VenueClient
>>>>>> 08/09/2006 11:15:27 AM -1376814176 JabberClient
>>>>>> 'AG-Tech-Room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>> 08/09/2006 11:15:27 AM -1376814176 bajjer.io io.py:122 DEBUG
>>>>>> SEND: <presence
>>>>>> to="AG-Tech-Room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>> running beacon
>>>>>> 08/09/2006 11:15:27 AM -1376814176 RTPBeacon RTPBeacon.py:296
>>>>>> DEBUG Called Stop.
>>>>>> 233.59.192.114/63534
>>>>>> 08/09/2006 11:15:27 AM -1376814176 RTPBeacon RTPBeacon.py:278
>>>>>> DEBUG Called Start.
>>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.io io.py:161 DEBUG
>>>>>> RECV: <presence
>>>>>> from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>> Zimmerman'><x/><x
>>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize
>>>>>> 08/09/2006 11:15:27 AM -1345344608 JabberClient
>>>>>> 08/09/2006 11:15:27 AM -1345344608 VenueClient
>>>>>> from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>ag-tech-room(venueserver2.westgrid.ca)</body></message>
>>>>>> ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.go:
>>>>>> from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>This
>>>>>> milton.mcs.anl.gov 53368
>>>>>> This room supports the MUC protocol.
>>>>>> 08/09/2006 11:15:27 AM -1208600896 EventClient
>>>>>> InsecureVenueEventClient.py:77 INFO BaseVenueEventClient lost
>>>>>> connection.
>>>>>> Todd Zimmerman has joined this session
>>>>>> milton.mcs.anl.gov 53100
>>>>>> milton.mcs.anl.gov 53004
>>>>>> 08/09/2006 11:15:27 AM -1208600896 GroupMsgClient
>>>>>> 8180087163ff6536598e606758d7f94f
>>>>>> connection.
>>>>>> 08/09/2006 11:15:28 AM -1376814176 VenueClient
>>>>>> milton.mcs.anl.gov 52582
>>>>>> 08/09/2006 11:15:28 AM -1376814176 RTPBeacon RTPBeacon.py:296
>>>>>> DEBUG Called Stop.
>>>>>> running beacon
>>>>>> DEBUG Called Stop.
>>>>>> milton.mcs.anl.gov/52582
>>>>>> 08/09/2006 11:15:28 AM -1376814176 RTPBeacon RTPBeacon.py:278
>>>>>> DEBUG Called Start.
>>>>>> 08/09/2006 11:15:28 AM -1376814176 NodeService
>>>>>> 08/09/2006 11:15:28 AM -1398592608 ServiceManager
>>>>>> 8180087163ff629be074b224aad547b3, L16, 16000, 1, consumer, audio,
>>>>>> 8180087163ff629be074b224aad547b3, L16, 8000, 1, consumer, audio,
>>>>>> 8180087163ff629be074b224aad547b3, L8, 16000, 1, consumer, audio,
>>>>>> 8180087163ff629be074b224aad547b3, L8, 8000, 1, consumer, audio,
>>>>>> 8180087163ff629be074b224aad547b3, PCMU, 16000, 1, consumer,
>>>>>> audio, 8180087163ff629be074b224aad547b3, PCMU, 8000, 1, consumer,
>>>>>> audio, 8180087163ff629be074b224aad547b3, GSM, 16000, 1, consumer,
>>>>>> audio, 8180087163ff629be074b224aad547b3, GSM, 8000, 1]) to
>>>>>> service:
>>>>>> AGNodeService.py:718 ERROR Exception in
>>>>>> AGNodeService.__SendStreamsToService.
>>>>>> File
>>>>>> if c.matches(cap):
>>>>>> File
>>>>>> VenueClient.py:1199 ERROR Error setting streams
>>>>>> File
>>>>>> "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/VenueClient.py",
>>>>>> line 1197, in UpdateNodeService
>>>>>> self.nodeService.SetStreams( self.streamDescList )
>>>>>> File
>>>>>> line 340, in SetStreams
>>>>>> self.__SendStreamsToService( service.uri )
>>>>>> File
>>>>>> line 723, in __SendStreamsToService
>>>>>> 08/09/2006 11:15:28 AM -1225692256 RTPBeacon RTPBeacon.py:289
>>>>>> 08/09/2006 11:15:30 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:30 AM -1225692256 ServiceManager
>>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeManagementUIClasses
>>>>>> DebugService
>>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeService
>>>>>> File
>>>>>> if c.matches(cap):
>>>>>> File
>>>>>> AGNodeService.py:282 ERROR
>>>>>> File
>>>>>> File
>>>>>> NodeManagementUIClasses.py:1043 ERROR Error enabling service
>>>>>> File
>>>>>> line 1037, in EnableService
>>>>>> File
>>>>>> File
>>>>>> 08/09/2006 11:15:38 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:38 AM -1225692256 ServiceManager
>>>>>> DebugService
>>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeService
>>>>>> File
>>>>>> if c.matches(cap):
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> 08/09/2006 11:15:54 AM -1208600896 VenueClient
>>>>>> VenueClientUI.py:2200 INFO --------- END VenueClient
>>>>>> 08/09/2006 11:15:54 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:54 AM -1225692256 ServiceManager
>>>>>> 08/09/2006 11:15:55 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:55 AM -1225692256 ServiceManager
>>>>>> 08/09/2006 11:15:56 AM -1208600896 NodeService
>>>>>> 08/09/2006 11:15:56 AM -1208600896 VenueClient
>>>>>> 08/09/2006 11:15:56 AM -1208600896 JabberClient
>>>>>> 08/09/2006 11:15:56 AM -1208600896 bajjer.io io.py:122 DEBUG
>>>>>> SEND: <presence
>>>>>> 08/09/2006 11:15:56 AM -1208600896 RTPBeacon RTPBeacon.py:296
>>>>>> DEBUG Called Stop.
>>>>>> 08/09/2006 11:15:56 AM -1208600896 ServiceManager
>>>>>> AGServiceManager.py:70 INFO AGServiceManager.Shutdown
>>>>>> AGServiceManager.py:71 INFO Remove services
>>>>>> AGServiceManager.py:208 INFO AGServiceManager.RemoveServices
>>>>>> AGServiceManager.py:162 INFO AGServiceManager.RemoveService
>>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.io io.py:161 DEBUG
>>>>>> RECV: <presence
>>>>>> type='unavailable'
>>>>>> Zimmerman'><x/><x
>>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize
>>>>>> 08/09/2006 11:15:56 AM -1366324320 RTPBeacon RTPBeacon.py:289
>>>>>> 08/09/2006 11:15:56 AM -1345344608 JabberClient
>>>>>> 08/09/2006 11:15:56 AM -1345344608 VenueClient
>>>>>> 08/09/2006 11:15:58 AM -1208600896 ServiceManager
>>>>>> 08/09/2006 11:16:00 AM -1208600896 ServiceManager
>>>>>> 08/09/2006 11:16:02 AM -1208600896 ServiceManager
>>>>>> AGServiceManager.py:73 INFO Stop network interface
>>>>>> 08/09/2006 11:16:02 AM -1208600896 RTPBeacon RTPBeacon.py:296
>>>>>> DEBUG Called Stop.
Dipl.-Inf. Michael Braitmaier
HLRS - Visualization / Video Conferencing
University of Stuttgart
Germany
Phone: ++49 711 685 65996
Fax : ++49 711 682 357
Website: http://www.hlrs.de/people/braitmaier/
