[AG-DEV] Example RSS for AG3 scheduling feeds
Todd Zimmerman
toddz at sfu.ca
Wed Apr 12 00:50:50 CDT 2006
Totally agree.
We are currently using WebCalendar (http://www.k5n.us/webcalendar.php) to book virtual venues on our
venue server - which can currently export to iCal (which I could probably munge into a usable rss
feed) and in the next release (1.1) will be able to directly export to rss.
So we should end up with an online booking system with the ability to pull the bookings out to a
webpage for the 'upcoming events' section - and directly into the AG3 clients.
Hoping this all works out - because it'll be a _very_ nice addition to the infrastructure.
Todd
Thomas D. Uram wrote:
> One minor suggestion as you set up a feed: I've been thinking I'd
> prefer to set it
> up as a cgi script instead of a static doc, so I could have
> some programmatic control over it.
> On 4/11/06 6:26 PM, Todd Zimmerman wrote:
>> I gotta say..... this is the coolest thing.
>> Finally getting around to testing this out and we are _all_ over
>> this. Got a test feed running at
>> www.westgrid.ca/collabvis/westgrid-ag.rss for anyone that is interested.
>> Thanks Tom et al,
>> Todd...
>>> AG3 has an integrated RSS reader for presenting schedule data directly
>>> in the VenueClient,
>>> from which users can go to event webpages or join event venues. I'm
>>> giving an example
>>> here of the format of the feed used, so people can publish their own
>>> feeds, mostly for
>>> testing with the current beta release.
>>> We're using RSS2. Everything we're doing conforms to the spec, which
>>> can be
>>> found here:
>>> http://blogs.law.harvard.edu/tech/rss
>>> A couple notable points:
>>> - the venue url goes in an enclosure section (exemplified below)
>>> - the date format must be adhered to for correct parsing, as specified
>>> in section 5 of
>>> RFC822.
>>> Here's the sample RSS (also up at
>>> http://www.mcs.anl.gov/~turam/AG/sample.rss):
>>> <rss version="2.0">
>>> <channel>
>>> <pubDate>28 Jan 2006 09:00:00 UT</pubDate>
>>> <title>AccessGrid Dev</title>
>>> <link>http://www.mcs.anl.gov/fl/research/accessgrid</link>
>>> <description>Upcoming events hosted by the Argonne Access Grid
>>> Developers</description>
>>> <managingEditor>ag-info at mcs.anl.gov</managingEditor>
>>> <item>
>>> <pubDate>16 Feb 2006 16:00:00 UT</pubDate>
>>> <title>Access Grid Test Meeting</title>
>>> <description>empty description</description>
>>> <enclosure
>>> url="https://vv3.mcs.anl.gov:8000/Venues/7f0000014bcd04036f4482e84f4d45bc"
>>> length="1" type="application/x-ag-venueclient"/>
>>> </item>
>>> </channel>
>>> </rss>
>>> And some notes on that:
>>> - The format is clearly a channel with some channel data (pubDate,
>>> title, etc.) and an item.
>>> There can be multiple items in a channel.
>>> - The channel title and pubDate are shown in the VenueClient.
>>> - The channel link, description, and managingEditor are not currently
>>> used, but I'd
>>> like to use them in the future, so include them here.
>>> - All of the data in the item is used, except the description which I'd
>>> like to use in
>>> the future.
>>> Comments are encouraged.
>>> Tom
