[AG-DEV] Using AuthorizationManager
Eric Olson
eolson at mcs.anl.gov
Tue Jul 19 12:54:40 CDT 2005
Michael,
Looks like you've found a bug. Here is another way to access a venue's
authorization manager:
venueAuthUrl = venueUrl + "/Authorization"
from AccessGrid.Security.AuthorizationManager import \
AuthorizationManagerIW
am = AuthorizationManagerIW(venueAuthUrl)
am.AddRole('HappyUsers')
We normally wouldn't expect you to know a hardcoded path like
"/Authorization", but a related bug would prevent you from retrieving
that as well. We'll fix these for future releases.
In case it helps with what you're working on, with the current release
there is a standalone UI for managing authorization. We've used it
mostly for testing, but please report bugs if you find any.
python AccessGrid/Security/wxgui/AuthorizationUI.py url/Authorization
That should work with servers, venues, and shared applications.
Eric
Michael Miller wrote:
> Hey folks,
> I'm trying to create a role on a 2.3 venue server thus:
> self.currentvenue.AddRole('HappyUsers')
> Here's the result:
> File
> "C:\Python23\Lib\site-packages\AccessGrid\Security\AuthorizationManager.py",
> line 952, in AddRole
> role = self.proxy.AddRole(r)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
> __call__
> return self.__r_call(*args, **kw)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
> __r_call
> self.__hd, self.__ma)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 389, in __call
> raise p
> SOAPpy.Types.faultType: <Fault SOAP-ENV:Server: Method Failed:
> Venues:000000ffe1
> 505263008d008e0040000b572:AddRole>
> I get similar results when trying to ListRoles as well. Can someone
> tell me why this is failing?
