[AG-DEV] Vic and Rat Encryption
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Mon Jul 11 11:05:30 CDT 2005
The version I was trying was the source downloaded from the UCL website. It
claims to be version 4.2.23 and is using the UCL common library qfDES.
The openssl command is:
openssl des-cbc -K 230DCDF1D6FB7CB3 -iv 0000000000000000 -in indata -out
outdata
The password is "testkey" which gets turned into the key above by RAT. I
have attached the indata file.
For rat, I put the following lines at the end of des_initialize in rtp.c in
the common directory:
testdata = (char *) xmalloc(64);
for (i = 0; i < 64; i++) {
testdata[i] = i;
des_encrypt(session, testdata, 64, initVec);
testfile = fopen("testfile", "w");
fwrite(testdata, 64, 1, testfile);
fclose(testfile);
Hope this helps,
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: Colin Perkins [mailto:csp at csperkins.org]
> Sent: 11 July 2005 16:49
> To: Andrew Rowley
> Cc: 'Rhys Hawkins'; ag-dev at mcs.anl.gov
> Subject: Re: [AG-DEV] Vic and Rat Encryption
> On 11 Jul 2005, at 16:14, Andrew Rowley wrote:
> > I was using vic and rat from the command line and forcing DES
> > encryption.
> > It turns out that I needed to generate the key differently and just
> > use
> > DES/CBC/NoPadding to do this.
> > Doing some further experiments, unless I am doing this wrong, it
> > would seem
> > that the DES encryption in vic and rat is broken. I downloaded the
> > source
> > code and then modified it as follows:
> > When rat initialises the des encryption, I output the 8-byte key to
> > a file.
> > I then generate an array of bytes consisting of the numbers 0-63 in
> > order.
> > I then encrypt this and output this to a file.
> > I then take the same key and the initialisation vector of 0s and
> > run openssl
> > in des-cbc mode with the same key and iv on the same input. This
> > gives a
> > completely different output to that given by rat. The openssl
> > output is the
> > same output as is given by the Java encryption using DES/CBC/
> > NoPadding.
> Which version of rat is this - did you test with the version from the
> UCL CVS?
> Can you send your test routines to illustrate the problem? I'm not
> aware of any problems with the DES code in rat, although there were
> issues with the AES code that I fixed relatively recently.
> Colin
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20050711/646557aa/attachment.obj>
