Fwd: ssmping
Thomas D. Uram
turam at mcs.anl.gov
Fri Apr 22 10:35:31 CDT 2005
Very cool, even if it is only for SSM. We could build a similar tool for ASM.
Also interesting is the mention of dbeacon at the bottom of the ssmping page:
http://artemis.av.it.pt/~hsantos/dbeacon/
Tom
On 04/22/05 09:55, Robert Olson wrote:
> some cool tech.
> Begin forwarded message:
> *From: *Stig Venaas <Stig.Venaas at uninett.no>
> *Date: *April 22, 2005 9:11:32 AM CDT
> *To: *wg-multicast at internet2.edu
> *Subject: ssmping
> Hi
> I've written a utility called ssmping. This is based on the ssmping
> idea by Pavan Namburi, Kamil Sarac and Kevin C. Almeroth. They way
> I've done this is slightly different however, I only use UDP and
> need no support from the network.
> The idea is pretty simple. On a host one runs a daemon called ssmpingd.
> Let's say the host has unicast address S.
> On a client you run a utility called ssmping which is sort of like
> normal ping. It joins (S,G) (with S the unicast address of the server
> and the group G is hardcoded), and then sends unicast UDP packets to S
> every second.
> When the daemon receives a unicast request, it will send a unicast
> packet, and also a multicast packet to G.
> The client should receive both the messages. If it receives the unicast
> but not the multicast, you know multicast doesn't work.
> The tool supports both IPv4 and IPv6. Let me give you an example.
> At ssmping.uninett.no I'm running ssmpingd. It has both IPv4 and IPv6
> multicast connectivity.
> At xiang.ecs.soton.ac.uk I run the client and get:
> sv at xiang sv $ ~/src/ssmping storhaugen.uninett.no
> ssmping joined (S,G) =
> (2001:700:1:7:290:27ff:fe22:7186,ff3e::4321:1234)
> pinging S from 2001:630:d0:111:250:fcff:fe6a:42b3
> unicast from 2001:700:1:7:290:27ff:fe22:7186, seq=0 dist=20 time=61.8ms
> unicast from 2001:700:1:7:290:27ff:fe22:7186, seq=1 dist=20 time=63.9ms
> unicast from 2001:700:1:7:290:27ff:fe22:7186, seq=2 dist=20 time=57.3ms
> multicast from 2001:700:1:7:290:27ff:fe22:7186, seq=2 dist=12
> time=59.7ms
> unicast from 2001:700:1:7:290:27ff:fe22:7186, seq=3 dist=20 time=55.8ms
> multicast from 2001:700:1:7:290:27ff:fe22:7186, seq=3 dist=12
> time=59.2ms
> unicast from 2001:700:1:7:290:27ff:fe22:7186, seq=4 dist=20 time=55.9ms
> multicast from 2001:700:1:7:290:27ff:fe22:7186, seq=4 dist=12
> time=59.2ms
> This means that multicast is working, but it took about 2s for the
> multicast tree to be built (the 2 first packets got lost).
> You can also see that there is 20 unicast hops from the source, but
> only 12 multicast hops. And that the delay is somewhat larger for
> multicast.
> At the server I see this:
> received request from 2001:630:d0:111:250:fcff:fe6a:42b3
> Note that it support both IPv4 and IPv6. It used IPv6 in this case
> because hostname is registered with both A and AAAA.
> You are welcome to try both client and server. You can try to ping
> ssmping.uninett.no or some other ssmping servers to check that you
> can receive IPv4 or IPv6 SSM from them. If you tell me your server
> name I can also try to ping you.
> I have a web page for ssmping at
> http://www.venaas.no/multicast/ssmping/
> You can find a list of public servers to ping there. I could also
> list yours if you want.
> At this web page you also find the sources. It's quite simple to
> build on Linux and relatively simple on Solaris. Those are the
> tested platforms so far. I would be happy if people tried it on
> other plaforms, but note that on the client side, you need a
> system that supports the source filter API, that speaks IGMPv3 or
> MLDv2 and of course a router doing that a well.
> Well, have a look at the web page if you're interested. And I'm
> happy for any comments, questions ets.
> Personally I've already made use of this tool for some debugging.
> Stig
