Web Service Interfaces
Ivan R. Judson
judson at mcs.anl.gov
Mon Sep 13 23:07:57 CDT 2004
here's a list of our interfaces, including type information where I could
find it. I'd like someone to take this list and finish the missing type
information and then fill in return type information.
>From this list we can quickly (and probably easily) define the types we care
about for 3.0 and generate wsdl/schemas for them, which will help start work
in the next cycle.
class AGNetworkService(SOAPInteface):
__init__(self, impl)
_authorize(self, *args, **kw) : True : False : Exception
Transform(self, streamList : list of StreamDescriptions) :
StopTransform(self, streamList : list of StreamDescriptions)
class AGServiceI(SOAPInterface):
def __init__(self,impl):
def _authorize(self, *args, **kw) : True : False : Exception
def Start(self):
def Stop(self):
def GetCapabilities( self ):
def GetResource( self ):
def SetResource( self, resourceStruct : AGResource):
def SetConfiguration(self, serviceConfig : ??? ):
def GetConfiguration( self ):
def ConfigureStream( self, streamDescStruct : StreamDescription):
def IsStarted( self ):
def SetEnabled(self, enabled : True or False):
def GetEnabled(self):
def Shutdown(self):
def SetIdentity(self, profileStruct : ClientProfile):
class AGServiceManagerI(SOAPInterface):
def __init__(self, impl : AGServiceManager):
def Shutdown(self):
def GetResources(self):
def DiscoverResources(self):
def AddServicePackage( self, serviceFile : string (path),
resourceStruct : AGResource, serviceConfigStruct : ???):
def AddService(self, serviceDescStruct : AGServiceDescription,
def RemoveService(self, serviceDescStruct : AGServiceDescription):
def RemoveServices(self):
def GetServices(self):
def GetAvailableServices(self):
def StopServices(self):
class SharedApplicationI(SOAPInterface, AuthorizationIMixIn):
def __init__(self, impl):
def GetId(self):
def Join(self, clientProfile : ClientProfile):
def GetComponents(self, private_token : string):
def GetParticipants(self, private_token : string):
def Leave(self, private_token : string):
def SetData(self, private_token : string, key : string, value :
<unconstrained>):
def GetData(self, private_token : string, key : string):
def GetDataKeys(self, private_token : string):
def GetDataChannel(self, private_token : string):
def GetVenueURL(self, private_token : string):
def SetParticipantStatus(self, private_token : string, status :
string):
def SetParticipantProfile(self, private_token : string, profile :
ClientProfile):
def GetState(self, private_token : string):
class VenueI(SOAPInterface, AuthorizationIMixIn):
def Enter(self, clientProfileStruct):
def GetClients(self):
def RegisterNetworkService(self, networkServiceDescription :
NetworkServiceDescription):
def UnRegisterNetworkService(self, networkServiceDescription :
def AddNetworkService(self, clientType, privateId: string):
def RemoveNetworkService(self, privateId : string):
def GetNetworkServices(self):
def GetCachedProfiles(self):
def Shutdown(self):
def AddService(self, servDescStruct : ServiceDescription ):
def RemoveService(self, servDescStruct : ServiceDescription ):
def UpdateService(self, servDescStruct : ServiceDescription ):
def SetConnections(self, connDescStructList : ConnectionDescription
List):
def AddConnection(self, connectionDescStruct :
ConnectionDescription):
def RemoveConnection(self, connectionDescription :
def GetConnections(self):
def SetEncryptMedia(self, value : True or False, key : string):
def GetEncryptMedia(self):
def RegenerateEncryptionKeys(self):
def SetDescription(self, description : string):
def GetDescription(self):
def SetName(self, name : string):
def GetName(self):
def AddStream(self, inStreamDescription : StreamDescription):
def RemoveStream(self, inStreamDescription : StreamDescription):
def GetStreams(self):
def GetStaticStreams(self):
def Exit(self, privateId : string):
def UpdateClientProfile(self, clientProfileStruct : ClientProfile):
def AddData(self, dataDescriptionStruct : DataDescription):
def RemoveData(self, dataDescriptionStruct : DataDescription):
def UpdateData(self, dataDescriptionStruct : DataDescription):
def GetDataStoreInformation(self):
def GetDataDescriptions(self):
def GetUploadDescriptor(self):
def GetApplication(self, aid : string):
def GetApplications(self):
def CreateApplication(self, name : string, description : string,
mimeType : string, aid : string):
def DestroyApplication(self, appId : string):
def UpdateApplication(self, appDescStruct : ApplicationDescription):
def AddNetworkLocationToStream(self, privateId : string, streamId :
string, networkLocationStruct : NetworkLocation):
def GetEventServiceLocation(self):
def ImportAuthorizationPolicy(self, policy : string):
def AllocateMulticastLocation(self):
def RecycleMulticastLocation(self, location :
MulticastNetworkLocation):
def AddSubjectToRole(self, subject : string, role_string : string):
def RemoveSubjectFromRole(self, subject : string, role : string):
def SetSubjectsInRole(self, subject_list : list of string,
def FlushRoles(self):
def GetUsersInRole(self, role_string : string):
def GetRoleNames(self):
def DetermineSubjectRoles(self):
class VenueServerI(SOAPInterface, AuthorizationIMixIn):
def Shutdown(self, secondsFromNow : integer):
def Checkpoint(self):
def AddVenue(self, venueDescStruct : VenueDescription):
def ModifyVenue(self, URL, venueDescStruct : VenueDescription):
def RemoveVenue(self, URL : string):
def GetVenues(self):
def GetDefaultVenue(self):
def SetDefaultVenue(self, URL : string):
def AddAdministrator(self, subjStr : string):
def RemoveAdministrator(self, string : string):
def GetAdministrators(self):
def SetStorageLocation(self, location : string):
def GetStorageLocation(self):
def SetAddressAllocationMethod(self, method : enum { RANDOM,
INTERVAL } ):
def GetAddressAllocationMethod(self):
def SetEncryptAllMedia(self, value : True or False):
def GetEncryptAllMedia(self):
def RegenerateEcryptionKeys(self):
def SetBackupServer(self, server : string):
def GetBackupServer(self):
def SetBaseAddress(self, address : string):
def GetBaseAddress(self):
def SetAddressMask(self, mask : string):
def GetAddressMask(self):
def DumpDebugInfo(self,flag : True or False):
