AG 2.3 Packaging
Douglas Kosovic
douglask at itee.uq.edu.au
Fri Sep 10 08:25:23 CDT 2004
Hi Ivan,
> These are worrisome. But I can't tell what's actually happening from them.
> Can you send the full list?
I have more or less the same problem Chris is describing, see the
following for the BuildSnapshot.py output:
http://www.itee.uq.edu.au/~douglask/log/
In the log output you'll see the following line:
cmd = cp QuickBridge /sandbox/agtk/dist-20040910_230034/bin
Where dist-20040910_230034/bin is not a dir, but the copied QuickBridge
file. So it is failing before that line.
Doug
