Updated agtk-2.3_beta2 ebuild
Ti Leggett
leggett at mcs.anl.gov
Fri Sep 3 15:04:48 CDT 2004
Here it is in all its glory
# Copyright 1999-2004 Gentoo Technologies, Inc.
# Distributed under the terms of the GNU General Public License v2
# $Header: $
inherit eutils distutils
DESCRIPTION="The Access Grid Toolkit"
HOMEPAGE="http://www.mcs.anl.gov/fl/research/accessgrid/"
SRC_URI="http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/${PV}/source/${P}.tar.bz2"
LICENSE="AGTPL"
SLOT="0"
KEYWORDS="x86"
IUSE=""
DEPEND=">=python-2.3
>=globus-client/globus-data-management-client-2.4.3
>=pyglobus-0.9.7
>=soappy-0.11.4
>=pyOpenSSL_AG-0.5.1.1
>=wxGTK-2.4.2
>=wxpython-2.4.2.4
>=xawtv-3.86
>=ag-media/rat-4.2.22
>=ag-media/vic-1.1.13
app-arch/unzip
app-arch/zip
!ag-libs/agtk-cvs"
src_compile() {
if [ ${PR} = "r0" ]; then
doc_ver=${P}
else
doc_ver=${PVR}
fi
einfo "Fixing documentation path"
sed -i s/\"AccessGrid\",\ \"Documentation\"/\"${doc_ver}\",\ \"Documentation\"/ ${S}/AccessGrid/Platform/unix/Config.py
if [ ${?} -ne 0 ]; then
eerror "sed failed to patch Config.py"
fi
distutils_src_compile
echo "--- Building QuickBridge" ${S}/services/network/QuickBridge
pushd ${S}/services/network/QuickBridge
echo " - list files"
ls
gcc -O -o QuickBridge QuickBridge.c
popd
src_install() {
${python} setup.py install --root=${D} --no-compile
rm -rf ${D}/usr/bin ${D}/usr/etc/init.d ${D}/usr/share/AccessGrid ${D}/usr/share/applnk ${D}/usr/share/gnome
mv ${D}/usr/etc ${D}/etc
dodoc COPYING.txt ChangeLog README README-developers TODO
mv ${D}/usr/share/doc/AccessGrid/Documentation ${D}/usr/share/doc/${PF}/.
rm -rf ${D}/usr/share/doc/AccessGrid
install -d ${D}/etc/AccessGrid/Services
install -d ${D}/etc/AccessGrid/Logs
echo "--- Building node service packages"
mkdir ${D}/etc/AccessGrid/NodeServices
pushd ${S}/services/node
ls
echo " - VideoService"
cp /usr/bin/vic .
zip ${D}/etc/AccessGrid/NodeServices/VideoService.zip VideoService.{py,svc} vic
unzip -l ${D}/etc/AccessGrid/NodeServices/VideoService.zip
echo " - VideoProducerService"
zip ${D}/etc/AccessGrid/NodeServices/VideoProducerService.zip VideoProducerService.{py,svc} vic
unzip -l ${D}/etc/AccessGrid/NodeServices/VideoProducerService.zip
echo " - VideoConsumerService"
zip ${D}/etc/AccessGrid/NodeServices/VideoConsumerService.zip VideoConsumerService.{py,svc} vic
unzip -l ${D}/etc/AccessGrid/NodeServices/VideoConsumerService.zip
echo " - AudioService"
cp /usr/bin/rat* .
mv rat-4.2.22-kill rat-kill
zip ${D}/etc/AccessGrid/NodeServices/AudioService.zip AudioService.{py,svc} rat rat-4.2.22 rat-4.2.22-media rat-4.2.22-ui rat-kill
unzip -l ${D}/etc/AccessGrid/NodeServices/AudioService.zip
popd
echo "--- Copying shared application packages"
cp -a ${FILESDIR}/SharedApplications ${D}/etc/AccessGrid
echo "--- Copying QuickBridge"
ls ${S}/services/network/QuickBridge/QuickBridge
mkdir ${D}/usr/bin
cp -a -v ${S}/services/network/QuickBridge/QuickBridge ${D}/usr/bin
echo "--- Configuring executable scripts"
dobin bin/AGNodeService.py \
bin/AGServiceManager.py \
bin/BridgeServer.py \
bin/CertificateManager.py \
bin/CertificateRequestTool.py \
tools/GoToVenue.py \
bin/NodeManagement.py \
bin/NodeSetupWizard.py \
bin/VenueClient.py \
bin/VenueManagement.py \
bin/VenueServer.py \
bin/agpm.py \
bin/certmgr.py
