FW: [OpenH323][OPAL] External RTP stack
Ivan R. Judson
judson at mcs.anl.gov
Thu Oct 21 08:26:33 CDT 2004
interesting openh323/rtp information
-----Original Message-----
From: openh323-admin at openh323.org [mailto:openh323-admin at openh323.org] On
Behalf Of Craig Southeren
Sent: Thursday, October 21, 2004 4:35 AM
To: Guillaume FRAYSSE; openh323 at openh323.org
Subject: Re: [OpenH323][OPAL] External RTP stack
Guillaume,
It is intended that OPAL should provide the same mechanisms for using an
external RTP stack as OpenH323. The current OpenH323 API is documented at
http://www.voxgratia.org/docs/external_rtp.html
We've not yet had the time to make the SIP code within OPAL conform to this
API. Perhaps you could assist in this?
Craig
On Thu, 21 Oct 2004 11:07:44 +0200
Guillaume FRAYSSE <gfraysse at cvf.fr> wrote:
> Hi,
> I asked some questions here and I never really got a satisfying
> answer.
> Here's my problem, I am using OPAL on a telephony platform which uses
> an hardware RTP solution. The card we use has its own IP adress,
> different from the one used by the SIP stack.
> I didn't find a way to implement that using OPAL as it is now. I used
> some tricks to make it work, but it doesn't satisfy me, neither my
> boss.
> What I understand from reading the code is that it is not possible
> yet, the SDP stack seem to use the same IP adress than the SIP stack.
> Maybe there is a way but I don't see how to do it. If there is one, or
> if anybody already did that I'd love to hear from them.
> If it isn't possible, when will it be ? I can help to do it, as we
> really need it here. I just don't want to implement some workaround
> that wouldn't be integrated in OPAL and that I would have to merge
> with every new release of OPAl to finally drop it once a solution is
> implemented.
> Apart from that OPAL is very satisfying, I am able to place H323 and
> SIP calls using various softphones. This is the only drawback so far.
> Regards,
> Guillaume
Craig Southeren craigs at postincrement.com / craigs at voxgratia.org
Phone: +61 243654666 ICQ: #86852844
Fax: +61 243673140 MSN: craig_southeren at hotmail.com
Mobile: +61 417231046 Jabber: craigs at jabber.voxgratia.org
Post Increment - Consulting & Services http://www.postincrement.com
Vox Gratia - The Open Source VoIP portal http://www.voxgratia.org Raving
Of A Strange Mind - the VoIP blog http://www.southeren.com/blog
Check the FAQ before asking! - http://www.openh323.org/~openh323/fom.cgi
The OpenH323 Project mailing list, using Mailman. To unsubscribe or change
your subscription options, goto
http://www.openh323.org/mailman/listinfo/openh323
Maintained by Quicknet Technologies, Inc - http://www.quicknet.net
