Network Services Status
Rick Stevens
stevens at mcs.anl.gov
Mon Nov 29 07:38:45 CST 2004
Thans Susanne,
These are very helpful...and I'm glad to see that we have been making
good progress on the network services prototypes.
Wed, 24 Nov 2004, Susanne Lefvert wrote:
> Here is an update on network services. Feel free to give comments.
> Selector
> Current State:
> Selecting a video stream works well for both Quicktime and VIC. Selecting
> audio works for the first stream, however, switching to a new stream
> causes Quicktime to fail.
> Suggested Improvements:
> * Recreate timestamps in rtp packages to make audio switching work
> properly
> * Enable multiple stream selection
> * Separate UI from service and make it run on Windows
> Transcoder:
> Current State:
> I used rat3 that can transform linear16 8kHz <-> pcmu 8kHz. An AG venue
> can, based on client capabilities, connect to the transcoder and send back
> appropriate streams to the clients.
> * Find/implement a transcoder that is capable of transcoding linear16
> 16kHz <-> pcmu 8kHz.
> Broadcaster
> Current State:
> When pointed at a venue, the broadcaster retrieves multicast addresses and
> starts the Selector for video and the Transcoder/Mixer (rat3) for audio.
> The selected video stream and mixed audio stream are sent to new
> multicast/unicast addresses. Next, the broadcaster writes a session
> description file and starts a web server where the sdp file is published.
> Quicktime can then be started from a URL and play back audio and display
> video from the venue.
> * Quicktime can only play back pcmu 8kHz audio. Find/create a
> mixer/transcoder that can perform linear16 16kHz -> pcmu 8kHz. (Quicktime
> fails when using rat3 as a transcoder in linear16 8kHz -> pcmu 8kHz mode)
> * Integrate a QuickBridge so we can send to more than one unicast address.
> * Audio is delayed ~2 seconds compared to video.
> Schemas
> Prototype xml schemas for node services and nodes can be found at:
> http://www-unix.mcs.anl.gov/~lefvert/AGEP/AGEP-0128.html
> /Susanne
