client preferences
Justin Binns
binns at mcs.anl.gov
Thu Nov 18 08:24:46 CST 2004
One quick comment on the ellipses - they're a fairly common GUI-ism for
notifying the user that the menu item will lead to a dialog rather than
a direct action (i.e. 'Print' vs 'Print...'). In that sense, it might
make more sense to keep them. Just a thought.
Justin
On Thu, 2004-11-18 at 08:01, Ivan R. Judson wrote:
> > > Looks good, here're my suggestions:
> > > 1) try to use a general get(option) => Value, set(option, value),
> > > list_options() and see if that'll work. I know the type
> > problems and
> > > checking can get gross, but this will be more maintainable over time
> > I'll change that, shouldn't be a problem.
> > > 2) remove unicast/multicast from menu, and enable audio/video
> > My reason to keep it here is to avoid getting a million users
> > ask how to switch over to unicast when the menu item gets
> > removed. But I guess it is better to move them sooner rather
> > than later. Maybe add that as a shortcut icon on a toolbar later.
> That sounds reasonable, it'd be nice to figure out where we put shortcuts
> like this and perhaps have a couple for this release :-)
> > > 3) move Manage My Node (without ...) to the top section.
> > Then I would like to remove "..." on every menu item.
> Go for it, ellipses seem silly to me.
> > > 4) remove "request a certificate" it's on the cert mgmt ui anyhow
> > > should My Venues be on the Tools menu?
> > I would keep that as it is for now since My Venues can grow
> > long and would probably look weird if it is placed as a
> > second menu item under Tools.
> > You can say that My Venues is a tool but it can also be
> > viewed as a short cut that users should have easy access to
> > (i.e. not hidden in sub menus).
> > Every browser I've looked at has a separate
> > bookmarks/favorites menu and since this is similar I would
> > argue to keep it separate (not that they
> > are right but I think it feels natural for people to have
> > that).
> Good argument, I wouldn't move it given your thoughts.
> --ivan
> > Thank you for your comments
> > Susanne
