client preferences
Ivan R. Judson
judson at mcs.anl.gov
Thu Nov 18 08:27:38 CST 2004
Makes sense, now I notice them in outlook too :-)
--Ivan
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Thursday, November 18, 2004 8:26 AM
> To: judson at mcs.anl.gov
> Cc: 'Susanne Lefvert'; ag-dev at mcs.anl.gov
> Subject: Re: client preferences
> The use of ellipses is standard UI design, on windows anyway.
> cf
> http://msdn.microsoft.com/library/default.asp?url=/library/en-
> us/dnwue/
> html/ch14c.asp in the section on "User interface text".
> > If a command requires additional information to complete
> its intended
> > action, and you use a dialog box to supply that information, follow
> > the command with an ellipsis (.). The ellipsis provides a
> visual cue
> > that the command requires additional information.
> --bob
> On Nov 18, 2004, at 8:01 AM, Ivan R. Judson wrote:
> >>> Looks good, here're my suggestions:
> >>> 1) try to use a general get(option) => Value, set(option, value),
> >>> list_options() and see if that'll work. I know the type
> >> problems and
> >>> checking can get gross, but this will be more
> maintainable over time
> >> I'll change that, shouldn't be a problem.
> >>> 2) remove unicast/multicast from menu, and enable audio/video
> >> My reason to keep it here is to avoid getting a million
> users ask how
> >> to switch over to unicast when the menu item gets removed. But I
> >> guess it is better to move them sooner rather than later.
> Maybe add
> >> that as a shortcut icon on a toolbar later.
> > That sounds reasonable, it'd be nice to figure out where we put
> > shortcuts like this and perhaps have a couple for this release :-)
> >>> 3) move Manage My Node (without ...) to the top section.
> >> Then I would like to remove "..." on every menu item.
> > Go for it, ellipses seem silly to me.
> >>> 4) remove "request a certificate" it's on the cert mgmt ui anyhow
> >>> should My Venues be on the Tools menu?
> >> I would keep that as it is for now since My Venues can
> grow long and
> >> would probably look weird if it is placed as a second menu
> item under
> >> Tools.
> >> You can say that My Venues is a tool but it can also be
> viewed as a
> >> short cut that users should have easy access to (i.e. not
> hidden in
> >> sub menus).
> >> Every browser I've looked at has a separate
> bookmarks/favorites menu
> >> and since this is similar I would argue to keep it
> separate (not that
> >> they are right but I think it feels natural for people to
> have that).
> > Good argument, I wouldn't move it given your thoughts.
> > --ivan
> >> Thank you for your comments
> >> Susanne
