[CVS AccessGrid] Toolkit.py:Added version command line option, exits after printer toolkit version.
Eric Olson
eolson at mcs.anl.gov
Tue Mar 23 17:05:59 CST 2004
We could use something in our versioning to indicate cvs or development
versions.
The Linux kernel uses even and odd numbers. I've also seen software
where the version increments automatically each day in cvs.
Any feelings on whether we need something or not?
Eric
On Tue, 23 Mar 2004, Ivan R. Judson wrote:
> Commit in AccessGrid/AccessGrid on MAIN
> Toolkit.py+10-2 | 1.29 -> 1.30
> ________________________________________________________________________________
> Toolkit.py 1.29 -> 1.30
> diff -u -r1.29 -r1.30
> --- Toolkit.py 22 Mar 2004 22:56:16 -0000 1.29
> +++ Toolkit.py 23 Mar 2004 22:14:13 -0000 1.30
> @@ -2,13 +2,13 @@
> # Name: Toolkit.py
> # Purpose: Toolkit-wide initialization and state management.
> # Created: 2003/05/06
> -# RCS-ID: $Id: Toolkit.py,v 1.29 2004/03/22 22:56:16 olson Exp $
> +# RCS-ID: $Id: Toolkit.py,v 1.30 2004/03/23 22:14:13 judson Exp $
> # Copyright: (c) 2002
> # Licence: See COPYING.TXT
> -__revision__ = "$Id: Toolkit.py,v 1.29 2004/03/22 22:56:16 olson Exp $"
> +__revision__ = "$Id: Toolkit.py,v 1.30 2004/03/23 22:14:13 judson Exp $"
> # Standard imports
> import os
> @@ -24,6 +24,7 @@
> from AccessGrid.Platform.Config import AGTkConfig, GlobusConfig
> from AccessGrid.Platform.Config import SystemConfig, UserConfig
> from AccessGrid.ServiceProfile import ServiceProfile
> +from AccessGrid.Version import GetVersion
> class AppBase:
> @@ -56,6 +57,9 @@
> self.parser.add_option("-c", "--configfile", dest="configfilename",
> metavar="CONFIGFILE", default=None,
> help="Specify a configuration file for the program.")
> + self.parser.add_option("--version", action="store_true", dest="version",
> + default=0,
> + help="Print out what version of the toolkit this is.")
> self.certMgrUI = None
> self.userConfig = None
> @@ -143,6 +147,10 @@
> (self.options, args) = self.parser.parse_args()
> + if self.options.version:
> + print "Access Grid Toolkit Version: ", GetVersion()
> + sys.exit(0)
> if self.options.debug:
> levelHandler = Log.HandleLoggers(self.defLogHandler,
> Log.GetDefaultLoggers())
> CVSspam 0.2.8
