FW: image markup
Ivan R. Judson
judson at mcs.anl.gov
Mon Mar 22 11:27:08 CST 2004
Dave is very cool :-)
> -----Original Message-----
> From: Dave Semeraro [mailto:semeraro at ncsa.uiuc.edu]
> Sent: Monday, March 22, 2004 11:18 AM
> To: Ivan R. Judson
> Subject: image markup
> Hey Ivan,
> I added some basic markup ability to the image viewer code.
> It works as before but now you can left click and drag to
> draw lines and stuff on the image. When you let go of the
> mouse the mark is put on the event channel and it appears on
> the other images. A weak attempt at keeping a list of marks
> on the server object has been made. No attempt to avoid race
> conditions was made so it may not work as advertised. At the
> current time if someone joins a session late they get all the
> markup that is in the server at that time. Like I said, it is
> kinda weak but its better than nothing. It works in windows
> and linux with no changes. Give it a test drive if you have
> the time. You should be able to just swap out the old
> AGBasicImage.py file in the appropriate places.
> Dave
> Dave Semeraro Ph.D.
> Visualization and Virtual Environments Group NCSA University
> of Illinois
> 605 E. Springfield Ave.
> Champaign, IL 61820
> Semeraro at ncsa.uiuc.edu
> (217) 244-1852
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20040322/262a3215/attachment.diff>
