I'm sorry you should source the below files.
On Thu, 2004-03-11 at 10:25, Ti Leggett wrote:
> At the end of these scripts, you should call:
> ${GLOBUS_LOCATION}/etc/user-env.{sh,csh} respectively.
> That way if there is already a globus env setup, this will reset
> everything to the desired locations (GLOBUS_PATH, SHLIB_PATH, etc).
