building pyGlobus under windows
Ivan R. Judson
judson at mcs.anl.gov
Tue Mar 2 15:09:49 CST 2004
Hey Matt,
Sorry I didn't get to this before now. Ugh.
What I've done is the following:
Grab bob gaffaney's latest code from http://www-unix.mcs.anl.gov/~gaffaney/;
Unzip it somewhere.
Check out pyglobus from cvs.
Then these two files matter:
- globus-makefile-header.py (put it in the bin of the winglobus dir)
- the attached modified pyglobus setup.py
Then you should be able to do normal pyglobus build stuff. The only caveat
is that there are various header files that didn't get copied to the
winglobus/include dir, so when the build fails you have to go copy them by
hand. I don't have a list of them handy, but it's only about 7 files total.
--Ivan
I've also attached a large zip of my environment in case that helps. Ok, I
didn't attach it, it's 33M, it's at http://www.mcs.anl.gov/~judson/wg.zip
> -----Original Message-----
> From: Matthew Rodriguez DSD staff [mailto:MKRodriguez at lbl.gov]
> Sent: Monday, March 01, 2004 4:46 PM
> To: Ivan R. Judson
> Subject: building pyGlobus under windows
> I'm trying to build pyGlobus under windows right now. I'm not
> a windows person, so I was wondering if you can tell me how you do it.
> Right now I'm going to see if I can do this using cygwin,
> globus-makefile-header.py and Bob Gaffaney's static libraries.
> Thanks,
> Matt
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20040302/8a53eb46/attachment.diff>
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20040302/8a53eb46/attachment-0001.diff>
