Queries about ANL Venue Server
Mary Fritsch
fritsch at mcs.anl.gov
Fri Jun 18 09:47:24 CDT 2004
Ivan can you answer this particular questions for Jon Lau... and copy me
jonlau at ngp.org.sg
I don't want to misspeak..
>I see. I'm still a little confused here about the Venue setup. Are all
>the venues in the ANL venue server hosted locally, or are there some of
>them links to venue servers created by other organisations? i.e. if I set
>up a venue server in Singapore, is there a way for me to pass the address
>of the Singapore's venue server to ANL so that the ANL's venue server can
>link to the one in Singapore? If its possible, are there other entities
>linked to ANL's venue server in this way?
At 09:06 AM 6/18/2004 +0800, you wrote:
>Hi Mary,
>Thanks so much for your help. Below are my responses in blue. Cheers.
>At 04:48 AM 6/18/2004, you wrote:
>>>1. I was told to register, and after registering, I'm seeing this error
>>>message "This site is inactive. The following information may be
>>>inaccurate." and the webpage follows to display my site information,
>>>etc. Could I ask what is meant by "site" here?
>>There are two scheduling systems in place, NCSA AG Scheduler is most
>>dominant and you simply put your site information within these
>>webpages. You might have to put info for the site BEFORE you add
>>yourself as a registrant. As you see you need to affiliate yourself with
>>a company existing.
>>http://agschedule.ncsa.uiuc.edu/register_user.asp
>>If you haven't listed your site yet, go here and put in information
>>FIRST, then register yourself.
>>http://agschedule.ncsa.uiuc.edu/addSiteReq.asp
>>"Don't see your site?" is the link to get here.
>Thanks.
>>>2. I've already registered Singapore in the Global Node Listing, but
>>>could I ask what is purpose of "Registering your site for bridging to ANL"?
>>This is really an older crutch to help folks not on multicast network
>>yet. Do not register for this type of bridging. AG 2.x has in place
>>one-click switch to unicast if your multicast isn't working.
>I see. Yes, I'm aware of AG 2.x having this unicast to multicast option
>in the menu. :-)
>>>3. Could ANL help to create a "National Grid (Singapore)" room in the
>>>Institutional Lobby for us?
>>We are not creating any new sites in the institution venue. We are
>>implementing a new automated way of doing this and all sites will need to
>>recreate the venue or add them if they never had a institution room with
>>us. Sorry about this down time for getting an institution venue.
>With regards to the new automated venue server, when will this be up and
>running?
>Cheers!
>Jon LAU Khee Erng Tel : (65)-6874-8542
>Assistant Head (Technical) Fax : (65)-6872-1361
>National Grid Office Email : jonlau at ngp.org.sg
>21 Heng Mui Keng Terrace Web : www.ngp.org.sg
>Singapore 119613
>This email and all attachments are confidential and may be privileged. If
>you are not the intended recipient, please delete it and notify us
>immediately. Please do not copy or use it for any purpose, or disclose
>its contents to any other person. Thank you.
mary fritsch . futures lab . mcs . argonne national lab . 630 252 5297
