RAT debugging output from gcc-3.3.2 build
Ti Leggett
leggett at mcs.anl.gov
Tue Jun 1 11:12:13 CDT 2004
Here's the debugging output.
[pid/7770 +661 mbus_config.c] using Addr:224.255.222.239 Port:47000 Scope:HOSTLOCAL for MBUS
[pid/7770 +89 process.c] Running as root? PATH unmodified
[pid/7771 +110 main_ui.c] rat-ui started argc=5
[pid/7771 +661 mbus_config.c] using Addr:224.255.222.239 Port:47000 Scope:HOSTLOCAL for MBUS
[pid/7771 +129 main_ui.c] Waiting for mbus.waiting(rat-token-394f0a17) from controller...
[pid/7770 +885 mbus.c] received reliable msg 1, sending ACK
[pid/7771 +131 main_ui.c] [pid/7770 [pid/7771 +137 main_ui.c] Waiting for mbus.go(rat-token-394f0a17) from controller...
[pid/7770 +509 main_control.c] Waiting for rat-token-16b35fb5 from media engine...
[pid/7772 +88 main_engine.c] token[0] = rat-token-16b35fb5
[pid/7772 +165 auddev_oss.c] cannot open /dev/mixer0 - No such file or directory
[pid/7772 +261 auddev_oss.c] cannot open /dev/dsp0 - No such file or directory
[pid/7772 +165 auddev_oss.c] cannot open /dev/mixer1 - No such file or directory
[pid/7772 +261 auddev_oss.c] cannot open /dev/dsp1 - No such file or directory
[pid/7772 +165 auddev_oss.c] cannot open /dev/mixer2 - No such file or directory
[pid/7772 +261 auddev_oss.c] cannot open /dev/dsp2 - No such file or directory
[pid/7772 +165 auddev_oss.c] cannot open /dev/mixer3 - No such file or directory
[pid/7772 +261 auddev_oss.c] cannot open /dev/dsp3 - No such file or directory
[pid/7772 +479 auddev_oss.c] number of valid devices: 0
[pid/7772 +98 auddev_ixj.c] QuickNet has no mixer
[pid/7772 +103 auddev_ixj.c] Can not open /dev/phone0
[pid/7772 +155 auddev_ixj.c] cannot open /dev/phone0 - No such file or directory
[pid/7772 +155 auddev_ixj.c] cannot open /dev/phone1 - No such file or directory
[pid/7772 +155 auddev_ixj.c] cannot open /dev/phone2 - No such file or directory
[pid/7772 +155 auddev_ixj.c] cannot open /dev/phone3 - No such file or directory
[pid/7772 +199 auddev_ixj.c] number of valid devices: 0
[pid/7772 +107 auddev_trans.c] Cannot open transcoder audio device: not a transcoder
[pid/7772 +1236 auddev.c] Added "No Audio Device" to audio device table
[pid/7772 +204 channel.c] Created encoder: "None"
[pid/7772 +235 audio.c] Change device requested.
[pid/7772 +615 auddev.c] Opened device: No Audio Device
[pid/7772 +645 auddev.c] Input: 16-bit signed linear,8-kHz,Mono
[pid/7772 +656 auddev.c] Output: 16-bit signed linear,8-kHz,Mono
[pid/7772 +165 transmit.c] Unit duration 160 channels 1
[pid/7772 +106 mix.c] Mixer created. Aligned to 0 8000kHz
[pid/7772 +296 audio.c] 0x00000000 0x00000101
[pid/7772 +661 mbus_config.c] using Addr:224.255.222.239 Port:47000 Scope:HOSTLOCAL for MBUS
[pid/7772 +138 main_engine.c] Need mbus.waiting(rat-token-16b35fb5) from controller...
[pid/7772 +153 main_engine.c] Sending mbus.go(rat-token-16b35fb5) to controller...
[pid/7772 +158 main_engine.c] Got all needed mbus.waiting() messages from controller
[pid/7772 +174 main_engine.c] Sent all mbus.go() messages to controller
[pid/7772 +179 main_engine.c] Need mbus.go("rat-token-16b35fb5") from controller...
[pid/7770 +511 main_control.c] ...got it
[pid/7772 +885 mbus.c] received reliable msg 16, sending ACK
[pid/7772 +625 rtp.c] Created database entry for ssrc 0x3c94d3bb (1 valid sources)
[pid/7771 +885 mbus.c] received reliable msg 17, sending ACK
[pid/7771 +139 main_ui.c] ...got it
[pid/7771 +142 main_ui.c] Waiting for mbus.waiting(rat-ui-requested) from media engine...
[pid/7770 +519 main_control.c] User interface is (media:audio module:ui app:rat id:3221222444)
[pid/7772 +885 mbus.c] received reliable msg 19, sending ACK
[pid/7772 +1544 mbus_engine.c] Got required mbus.go(rat-token-16b35fb5)
[pid/7772 +197 main_engine.c] Got all needed mbus.go() messages from controller
[pid/7772 +327 audio.c] audio device reconfigure - nothing to do.
[pid/7772 +438 settings.c] gecos root name root
[pid/7772 +478 settings.c] username root root
[pid/7772 +426 audio.c] catch up! read_dur(176) > cushion_size(0)
[pid/7772 +390 mix.c] Getting new cushion 800 old 0
[pid/7772 +467 audio.c] Decreasing cushion
[pid/7770 +523 main_control.c] Media engine 0 is (media:audio module:engine app:rat session:0 id:2147483647)
[pid/7770 +525 main_control.c] Parsing options
[pid/7770 +529 main_control.c] Entering main loop
[pid/7772 +1522 mbus_engine.c] Got mbus.waiting(rat-ui-requested)
[pid/7770 +320 main_control.c] Caught signal 2
[pid/7770 +119 process.c] Killing process 7771
[pid/7770 +119 process.c] Killing process 7772
