Fwd: Testing AG software: Version AG2
Mary Fritsch
fritsch at mcs.anl.gov
Fri Jul 30 13:14:49 CDT 2004
interesting conversations on 1.x and 2.x compatibility for the large scale
conference "Virtual Conf on Genomics and Bioinformatics"
>X-MailScanner-From: willy_valdivia at orionbiosciences.com
>Approved-By: willy_valdivia at ORIONBIOSCIENCES.COM
>Date: Fri, 30 Jul 2004 08:23:04 -0700
>Reply-To: willy_valdivia at orionbiosciences.com
>Sender: "AG Virtual Conf. on Genomics and
>Bioinformatics" <VIRTCON at LISTSERV.NODAK.EDU>
>From: Willy Valdivia <willy_valdivia at orionbiosciences.com>
>Subject: Testing AG software: Version AG2
>Comments: To: Markus Buchhorn <Markus.Buchhorn at anu.edu.au>
>To: VIRTCON at LISTSERV.NODAK.EDU
>Hello Steve
>You raise a good point about the use of the AG2. Are we all in the same
>page about this issue of updating to AG2 before the conference. If this
>is true we will be able to run the slides that were previously posted as
>test?
>Cheers
>Willy
> > -------- Original Message --------
> > Subject: Re: [virtual genomics: Testing AG software]
> > From: "Markus Buchhorn" <Markus.Buchhorn at anu.edu.au>
> > Date: Thu, July 29, 2004 3:30 pm
> > At 09:41 AM 29/07/2004 -0400, Steve Gallo wrote:
> > >We didn't get a chance to test the slides, I had to install MS Java VM on
> > >XP, I had the Sun VM but DPPT doesn't seem to work with that. If we
> use DPPT
> > >I'm not sure if the videos and java app will run. If we use AG2 shared
> > >presentations then we'll lose part of the audience unless they do things
> > >manually.
> > This is actually a problem we should "nudge" somewhat. The central AG1
> systems will be shut down in September/October this year, and people will
> have to move to AG2 if they want to remain part of the global community
> (they can keep AG1 of course, but it will restrict who they can work
> with). dppt is no longer being developed (or supported), the
> shared-presentation stuff is.
> > I know there's some grief with the AG2.2 code at the moment, but
> AG2.1.2 is pretty solid. There's meant to be an AG2.3 release in August,
> or at least an update to 2.2, since the SC-Global conference is looming
> and we're about to start test cruises.
> > I don't know if we can provide some additional incentive to people to
> upgrade. SC-Global will mandate a release of 2.x, probably 2.3 or 2.2.x
> or you will miss out on content.
> > Something to consider....
> > Cheers,
> > Markus
> > Markus Buchhorn, ANU Internet Futures |Ph: +61 2 61258810
> > Markus.Buchhorn at anu.edu.au |Fx: +61 2 61259805
> > The Australian National University, Canberra 0200 |Mob: 0417 281429
mary fritsch . futures lab . mcs . argonne national lab . 630 252 5297
