ag 2.3 capability negotiation -- when?
Susanne Lefvert
lefvert at mcs.anl.gov
Thu Jul 15 15:37:01 CDT 2004
Hello Stuart,
I agree, the ideal design would allow clients to do capability-matching on
the fly. This could probably be done by adding an additional method to
the venue SOAP interface that would let clients negotiate capabilites
separate from the venue enter operation. My plan is to first implement
the simpler version of the design, that would require participants to
disconnect and reconnect before any changes take place, and then extend
it to be more flexible.
Thank you very much for your comments.
Susanne
On Thu, 15 Jul 2004, Stuart Levy wrote:
> I do have one question: is it clear when the capability-matching processing
> would be invoked? From p. 14 it looks as though it's just
> at venue entry time.
> You'd probably want operators to be able to change preferences, or
> install new capabilities, or disable broken capabilities(!) on the fly,
> while a session was in progress. When those things changed, then the
> set of active modules would need to be recomputed, right?
> Many stream->module associations would remain the same, but some modules
> would need to terminate, others be started, others be re-started with new
> parameter settings, etc. Implementation would be simpler if you insisted
> that participants must disconnect and reconnect before any changes took effect,
> but that sounds a lot less pleasant to use than if the system could discover
> the minimum set of changes required to accommodate the new environment.
> Cheers
> Stuart
