Extracting cert/key from IE pfx (pkcs12) file
Robert Olson
olson at mcs.anl.gov
Wed Jul 14 09:36:46 CDT 2004
certmgr should also be able to load pkcs12's directly.
On Wed, 14 Jul 2004, Ivan R. Judson wrote:
> If you have a cert in IE, you can export it to a pfx (portable key format?)
> which is really a pkcs12 formatted file. With these two commands you can
> extract the key and cert into files that we can import into the AGTk Cert
> Mgmt tools.
> --Ivan
> openssl pkcs12 -in file.pfx -clcerts -nokeys -out certfile.pem
> openssl pkcs12 -in file.pfx -nocerts -out keyfile.pem
