[AG-TECH] Unicast issues with vic/rat
    Ivan R. Judson
    judson at mcs.anl.gov
    Mon Jan 26 21:03:51 CST 2004
I'll apply it while I'm working on other vic stuff anyhow. I've also been
using the ag-media cvs module which means the rat patches for iphlpr.lib are
applied to vic as well. Dunno if that matters, but we're down to using a
single lib common and tcl/tk for the two apps.
I'll apply this patch to vic while I'm in here
--Ivan
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov
> [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
> Sent: Monday, January 26, 2004 8:50 PM
> To: ag-dev at mcs.anl.gov
> Subject: Fwd: Re: [AG-TECH] Unicast issues with vic/rat
> Aha, cool. We should get this applied to the AG vic; should
> reduce the firewall problems that folks are having.
> --bob
> >Date: Mon, 26 Jan 2004 18:44:27 -0800
> >From: Andrew Swan <aswan at cs.berkeley.edu>
> >To: Don Morton <Don.Morton at umontana.edu>
> >Cc: "Sergeant A. G. Tech" <ag-tech at mcs.anl.gov>,
> >    Jennifer Parham <jparham at cs.clemson.edu>, jeh at cs.clemson.edu,
> >    westall at cs.clemson.edu, Dan Schmiedt <willys at clemson.edu>,
> >    ron_crummett at hotmail.com
> >Subject: Re: [AG-TECH] Unicast issues with vic/rat
> >Mail-Followup-To: Don Morton <Don.Morton at umontana.edu>,
> >User-Agent: Mutt/1.4.1i
> >X-Spam-Status: No, hits=-5.4 required=5.0
> tests=EMAIL_ATTRIBUTION,IN_REP_TO,QUOTED_EMAIL_TEXT,REFERENCES,
> >               REPLY_WITH_QUOTES,USER_AGENT_MUTT
> >         version=2.55
> >X-Spam-Level:
> >X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
> >Sender: owner-ag-tech at mcs.anl.gov
> >X-Whitelist-by-bob: yes
> >Don Morton wrote:
> > > For some reason, there are folks who are trying to
> unicast in, and
> > > the end result seems to be that "we" can see them, but they can't
> > > see us.  Note that there's no multicast involved here -
> in one case,
> > > the bridge is simply being used as a "rendezvous point"
> > > for two unicast streams, but the same problems occur - I
> seem to be
> > > able to see/hear the remote site, but they can't see/hear me.
> > > My vague understanding of vic/rat, used with the QuickBridge, is
> > > that the clients send UDP datagrams out to the bridge on ports in
> > > the 50000 range, and they seem to receive UDP datagrams
> on ports in
> > > the 32000 range, and it "should" be that simple.
> >i'm not sure about rat but vic in unicast mode sends and receives on
> >the same port, which is specified on the command line.  (the
> ports in
> >your example were in the 50000 range).  the source port in
> packets sent
> >from vic will be an "ephemeral port" chosen by the operating system
> >which is likely what you are referring to as in the 32000 range.
> >the behavior you describe is consistent with a nat or a
> firewall that
> >builds dynamic rules that assumes vic will receive packets
> on the same
> >port that it sends them from.
> >for example, if the remote person joins your quickbridge on
> port 50186,
> >they start sending packets from source port
> >32456 (or some other port chosen by their operating system, but not
> >port 50186).  upon seeing these packets, the nat or firewall
> installs a
> >rule to forward packets from source port
> >50186 on the quickbridge addressed to destination port 32456 back to
> >the remote participant.  however, quickbridge is sending packets to
> >destination port 50186 so they never reach the remote site.
> >probably the easiest way to verify that this is the problem is to
> >rebuild vic with the attached patch and run the modified
> version at the
> >remote site.  or if you have openmash vic installed, you can
> just add
> >the flag "-rtptv" to the vic command line to get the same effect.
> >-Andrew
