help with vic firewall issue
Eric Olson
eolson at mcs.anl.gov
Mon Feb 16 13:40:19 CST 2004
Nope, the sending socket is created and bound (and does call connect)
before the receive socket is created and bound.
Tom suggested looking at rat, since it seems to work through the
firewall. -- and I don't think vic creates any more connections than rat.
It looks to me like rat is listening on UDP, but I don't see any
explicit UDP connections. Does that mean the UDP connect() is not really
necessary?
Eric
On Mon, 16 Feb 2004, Robert Olson wrote:
> Ah, right, vic uses two sockets.
> I suspect that's the problem. By any chance, is the reading socket created
> and bound before the sending socket? (I forget if vic uses a connect() on
> the outgoing udp socket).
> At 01:11 PM 2/16/2004, Eric Olson wrote:
> >Not only binding to the same port you're connecting to, but also listening
> >on that port as follows: (maybe that's what you were saying as well)
> >vic UDP eolson-laptop-34:25000->ag-tech.mcs.anl.gov:*
> >vic UDP eolson-laptop-34:25001->ag-tech.mcs.anl.gov:25001
> >vic UDP eolson-laptop-34:25001->ag-tech.mcs.anl.gov:*
> >Eric
> > > In particular, I'm wondering if it's allowable in unix to have a unicast
> > > UDP socket with a source port the same as the dest port, and, if
> > allowable,
> > > if it's interfering with teh communication.
> > > --bob
> > > At 01:02 PM 2/16/2004, Eric Olson wrote:
> > > >I don't have one, but I'll look around for one and see if I can find
> > > >something about this.
> > > >Thanks,
> > > >Eric
> > > > > Do you have a copy of the Stevens network book? I wonder if there's
> > some
> > > > > socket semantics issue coming up here..
> > > > > --bob
> > > > > At 12:50 PM 2/16/2004, Eric Olson wrote:
> > > > > >Yes, the problem occurs only when connecting to a bridge (with
> > linux vic).
> > > > > >When using the new firewall patch, linux vic's "address in use" error
> > > > > >prevents connecting to bridges.
