new pyGlbous
Ivan R. Judson
judson at mcs.anl.gov
Mon Feb 9 16:57:44 CST 2004
So not the latest from their cvs, then. We need to get to that ASAP. We're
running down on time if we want to do any significant amount of testing.
Can you work through that and see what's left to do?
--Ivan
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Monday, February 09, 2004 4:44 PM
> To: judson at mcs.anl.gov; ag-dev at mcs.anl.gov
> Subject: RE: new pyGlbous
> At 04:39 PM 2/9/2004, Ivan R. Judson wrote:
> >By up-to-date, what do you mean specifically?
> Up to date with respect to the FL CVS repo, meaning it has
> the SSL exceptions support that the new cert mgr uses, and
> that it is compiled against a winglobus that's compiled
> against openssl 0.9.6c so that encrypted channels work.
> >--Ivan
> > > From: owner-ag-dev at mcs.anl.gov
> > > [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
> > > Sent: Monday, February 09, 2004 4:08 PM
> > > To: ag-dev at mcs.anl.gov
> > > Subject: new pyGlbous
> > > Here:
> > > http://www-unix.mcs.anl.gov/~olson/AG/snaps/pyGlobus-2004-0209.exe
> > > you will find an up-to-date pyGlobus, built against the
> openssl that
> > > lets us use encrypted channels, and with ssl exceptions included
> > > (with a backwards-compatibility bit that lets it work
> properly with
> > > the 2.1.2 codebase).
> > > I'd like folks to give this a shot; if folks verify it
> works (or if
> > > time passes and noone says anything :-) I'll commit the cert mgmt
> > > code that depends on the exceptions being there for proper
> > > operation.
> > > --bob
