AGFocus article
Robert Olson
olson at mcs.anl.gov
Thu Feb 5 11:14:38 CST 2004
looks good; you might mention that the
DataStoreFileReader|DataStoreFileWriter return from OpenFile is intended
to work like a python filehandle.
--bob
At 11:08 AM 2/5/2004, Thomas D. Uram wrote:
>The attached article is being submitted today for the next AGFocus
>newsletter. It's short; could people take a minute to review it and send
>me any comments?
>Tom
>Developers Corner
>This article highlights support in the Access Grid toolkit for uploading
>data to and downloading data from the venue server.
>The AG2 toolkit enables users to share files securely and
>persistently. The venue acts like a shared file system, in many
>respects: files can be uploaded, downloaded, and removed. A file is
>owned by the person who uploaded it. And the file persists in the venue
>until it is removed.
>The Venue Client displays the data in the venue as part of the current
>venue state, and handles user requests for file manipulations. Files are
>uploaded and downloaded via a GSIHTTP connection to the DataStore. To
>remove a file, a SOAP call is made to the Venue, which passes the request
>to its DataStore.
>As of AG2.1, access to the DataStore API is encapsulated in the
>DataStoreClient module. This simplifies developer access to the
>DataStore. One can create a DataStoreClient object using the URL to the venue:
> DataStoreClient GetVenueDataStore(venueUrl)
>And then access the DataStore programmatically using the following interfaces.
> LoadData()
> Refresh the local data description cache
> DataDescription GetFileData(filename)
> Get the data description for the specified file
> Download(filename,localFile)
> Download the specified file to the given local file.
> Upload(localFile)
> Upload the specified local file
> RemoveFile(filename)
> Remove the specified file
> DataStoreFileReader|DataStoreFileWriter OpenFile(file,mode)
> Open a file in the DataStore with the specified mode ('r','w');
> the return value is determined by the mode. The file will
> be created when the Reader/Writer is Close'd.
> [filenames] QueryMatchingFiles(pattern)
> [filenames] QueryMatchingFilesMultiple(patternList)
> Find files in the local cache that match the specified pattern.
>This makes it possible for shared applications and other components to
>access venue data. The DataStoreClient is currently being used in the
>SharedPresentation application, and will be utilized in other parts of the
>code in the future. Developers should note that, while access to the data
>in a venue is relatively open to the individuals allowed in the venue,
>access controls may restrict data access considerably in the future.
>Standalone, interactive use of the DataStoreClient API is exemplified in
>the module itself. Executing the module directly, the user is presented
>with an ftp-like interface to the data store.
> [turam at munich AccessGrid]$ python2 DataStoreClient.py
> https://localhost:8000/Venues/default
> DataStore> ls
> 7lyz.pdb
> DataStore> get 7lyz.pdb
> Downloading
> https://localhost:8006/000000fa3e5ba31b007f00000000000133b/7lyz.pdb
> DataStore> quit
>This example is solely intended to exercise the module code, not to
>provide production functionality. But it serves as a useful example of
>the simplicity of programmatic access to data stores in AG2.
