Fwd: Re: can you point me in the right direction
    Thomas D. Uram
    turam at mcs.anl.gov
    Mon Aug  9 10:13:04 CDT 2004
fyi, I talked with Bob Riddle and he's all set.  He didn't have his
certificate imported, apparently.  He sent me his venue client log so I
could look at why the software didn't tell him.
Robert Olson wrote:
>> Date: Wed, 04 Aug 2004 11:10:38 -0400
>> From: Bob Riddle <bdr at internet2.edu>
>> User-Agent: Mozilla Thunderbird 0.7.1 (X11/20040626)
>> X-Accept-Language: en-us, en
>> To: Robert Olson <olson at mcs.anl.gov>
>> Cc: "Ivan R. Judson" <judson at mcs.anl.gov>
>> Subject: Re: can you point me in the right direction
>> X-Virus-Scanned: by mail.internet2.edu virus scanner
>> X-Spam-Status: No, hits=-2.5 required=5.0
>>         tests=EMAIL_ATTRIBUTION,IN_REP_TO,QUOTED_EMAIL_TEXT,REFERENCES,
>>               REPLY_WITH_QUOTES,USER_AGENT
>>         version=2.55
>> X-Spam-Level:
>> X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
>> X-Whitelist-by-bob: yes
>> It lets me say "okay, go on" and then the green bar moves fills about
>> 80% of the "install activity" bar and it just hangs forever.  I use
>> the task manager to kill it, then try to run the Venue Client ... but
>> no node is ever found.
>> Robert Olson wrote:
>>> Does it let you just cancel out from that error?
>>> At 09:24 AM 8/4/2004, Bob Riddle wrote:
>>>> I decided to upgrade our onsight AG node from 2.1.something to 2.2,
>>>> so I scrubbed the WinXP machine and installed the AG 2.2 stuff.  I'm
>>>> not having much luck getting the "Node Setup Wizard" to run ... it
>>>> tells me that there is no usercert.pem in the  Application
>>>> Data/userid/globus directory ... which isn't surprising since the
>>>> globus directory doesn't exist.  It's been a while since I've done
>>>> this so I must be missing something. I installed the Python stuff,
>>>> the wxwindows stuff, then the AG 2.2 toolkit and tried to run the
>>>> "Node Setup Wizard" with no luck.  I must have left my brain in
>>>> Australia ...
>>>> I munged through the bugzilla stuff but didn't find anything that
>>>> seemed to address this problem.  Any insight, advice, or ridicule
>>>> you would care to share?
>>>> Bob Riddle (bdr at internet2.edu)    Technologist,Internet2
>>>> 3025 Boardwalk, Suite 100         Ann Arbor, Michigan  48108
>>>> Business Phone: 734.913.4257      Fax Number:  734.913.4255
>>>> "Math illiteracy affects 7 out of every 5 people"
