[AG-TECH] CVS assistance - I'd LIKE to be able to check out the new stuff (fwd)
Ivan R. Judson
judson at mcs.anl.gov
Thu Apr 8 22:53:53 CDT 2004
Ag-tech is our developer list, I'm glad to see this on there :-)
We should get our docs updated, meanwhile help folks the best that we can.
Although, being completely honest (that we're currently trying to update
what "run from cvs" means to keep it simple) is the right thing to do at the
same time.
--Ivan
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov
> [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Eric Olson
> Sent: Thursday, April 08, 2004 6:33 PM
> To: ag-dev at mcs.anl.gov
> Subject: Re: [AG-TECH] CVS assistance - I'd LIKE to be able
> What should we do to keep people updated? Maybe start a
> developers mailing list? Or maybe it's simplest to list the
> current packages we require on a developer wiki page?
> Eric
> ---------- Forwarded message ----------
> Date: Thu, 08 Apr 2004 08:41:50 -0700
> From: Todd Zimmerman <toddz at sfu.ca>
> To: Randy Groves <randy.groves at boeing.com>
> Cc: ag-tech at mcs.anl.gov
> to check out
> the new stuff
> I agree,
> We're interested in extending some of of the service
> integration code; however, we're not sure whether the CVS
> code is the latest code or not...
> Unfortunately I missed the last townhall - so I'm not sure if
> it was brought up or not, but it would be nice to have
> current instructions on running the CVS code if at all possible.
> I've made it slightly farther than you, Randy - I installed
> the optik module ( download at
> http://sourceforge.net/project/showfiles.php?group_id=38019,
> unzip and run the setup.py file like: 'python setup.py install')
> I also installed the fpconst
> (http://www.analytics.washington.edu/downloads/fpconst/) the same way.
> Now I can get to a point where the VenueClient will start;
> however, --personalNode doesn't seem to work (?) - I seem to
> have to start the agNodeService and agServiceManager's separately.
> I can _almost_ connect to a venue.... I can see who is
> connected etc, but it seems to error out and no streams start etc.
> Collaboration & Visualization Technician
> WestGrid - www.westgrid.ca
> IRMACS - www.irmacs.com
> Ph. 604.268.6979
> Todd Zimmerman - toddz at sfu.ca
> Randy Groves wrote:
> > OK - I'm having a problem with the CVS (this is on RH9).
> > I've installed the binaries for wxPython, vic and rat from
> the 2.1.2
> > release.
> > I've grabbed the latest, and following the README-developer
> notes (which
> > are in need of revision), I made the 'cfg' directory, and ran:
> > python AccessGrid/tools/CvsSetup.py --agdir AccessGrid --dst cfg
> > (note the change - in the doc it's in 'bin')
> > This was done as root.
> > Then I logged in as my ag user and tried to run the VenueClient:
> > /usr/bin/VenueClient.py --personalNode
> > I get the following error:
> > Traceback (most recent call last):
> > File "./VenueClient.py", line 38, in ?
> > from AccessGrid.Toolkit import WXGUIApplication
> > File
> "/usr/local/src/ag/ag-cvs/AccessGrid/AccessGrid/Toolkit.py", line
> > 18, in
> > from optparse import OptionParser, Option
> > ImportError: No module named optparse
> > I've done some poking around, and so far, I don't see any
> mention of
> > this module. Is there a step that I'm missing? Should I
> be loading a
> > different wxPython from CVS?
> > I know you folks are busy, but I'd like to be able to check
> this out and
> > give what assistance I can.
> > Thanks!!
> > -randy
