help with soappy issue
Eric Olson
eolson at mcs.anl.gov
Mon Apr 5 20:55:14 CDT 2004
I've narrowed down a soappy issue I'm having to a problem with returning a
list of actions where any two actions include the same Role instance.
Using identical copies of the Role does not cause a problem.
I've attached a simple test case to show the problem. I can work on it
more tomorrow, but if anyone wants to take a look at it before i get in,
feel free.
This is the main thing preventing me from checking in things that enable
authorization.
Eric
#!/usr/bin/python2
import os
import sys
import xml
from AccessGrid.hosting import Client
from AccessGrid.VenueServer import VenueServerIW
from AccessGrid.Platform import isWindows
from AccessGrid.Platform.Config import UserConfig
from AccessGrid.Toolkit import CmdlineApplication
from AccessGrid.Toolkit import Application, UserConfig
def TestActions():
friendRole = AllowRole("friends")
enemyRole = DenyRole("enemies")
#actionList = [Action("1", [friendRole, enemyRole]), Action("2", [friendRole, enemyRole])]
# Works
#actionList = [Action("1", [friendRole]), Action("2", [enemyRole])]
# Works
#import copy
#actionList = [Action("1", [friendRole]), Action("2", [copy.deepcopy(friendRole)])]
# Breaks
actionList = [Action("1", [friendRole]), Action("2", [friendRole])]
return actionList
app = CmdlineApplication()
app.Initialize()
from AccessGrid.Security.Action import Action
from AccessGrid.Security.Role import Role, AllowRole, DenyRole
from AccessGrid.Security.X509Subject import CreateSubjectFromString
from AccessGrid.hosting import Decorate, Reconstitute
#actionList = SampleActions()
actionList = TestActions()
print "Before Decorate:\n", actionList, "\n"
actionsDec = Decorate(actionList)
print "After Decorate:\n", actionsDec, "\n"
from SOAPpy import parseSOAP, parseSOAPRPC, buildSOAP
msg = buildSOAP(actionsDec)
print "after buildSOAP:\n", msg, "\n"
p = parseSOAPRPC(msg)
print "after parseSOAP:\n", p, "\n"
actions = Reconstitute(p)
print "after Reconstitute:\n"
# --- breaks here
for a in actions:
print "Action:", a
# --- also would break after the following
domImpl = xml.dom.minidom.getDOMImplementation()
authDoc = domImpl.createDocument(xml.dom.minidom.EMPTY_NAMESPACE,
"AuthorizationPolicy", None)
authP = authDoc.documentElement
for a in actions:
authP.appendChild(a.ToXML(authDoc))
rval = authDoc.toxml()
