Python detection code for InnoSetup
Robert Olson
olson at mcs.anl.gov
Mon Sep 29 13:19:00 CDT 2003
and a different version that uses enumeration of the pythoncore key to find
all of 'em.
--bob
At 10:31 AM 9/29/2003 -0500, Robert Olson wrote:
>Sending this off for future reference since it doesn't belong in the .iss
>I'm working on at the moment.
>--bob
var
PythonPaths, PythonNames, PythonKeyNames : TArrayOfString;
PythonPathVals: TArrayOfString;
MultiplePythonInstalls: Boolean;
// External functions:
// InnoSetup 2 versions:
//function RegOpenKeyEx(RootKey : Integer;subkey : string;options: integer;sec:integer;valu:integer): integer; external 'advapi32' name 'RegOpenKeyExA'; stdcall;
//function RegCloseKey(valu:integer): integer; external 'advapi32' name 'RegCloseKey'; stdcall;
//function RegEnumKeyEx(hKey: Integer;dwIndex: Integer; lpName : Pchar; lpcbName: PChar;lpReserved: Integer;lpClass: Pchar;lpcbClass: Integer;lpFTLWT: Integer): Integer; external 'advapi32' name 'RegEnumKeyExA'; stdcall;
// InnoSetup 3 versions:
function RegOpenKeyEx(RootKey : Integer;SubKey: String;Options: Integer;Sec: Integer; Valu: Integer): Integer; external 'RegOpenKeyExA at advapi32.dll stdcall';
function RegCloseKey(Valu: Integer): Integer; External 'RegCloseKey at advapi32.dll stdcall';
function RegEnumKeyEx(hKey: Integer;dwIndex: Integer; lpName : Pchar; lpcbName: PChar;lpReserved: Integer;lpClass: Pchar;lpcbClass: Integer;lpFTLWT: Integer): Integer; external 'RegEnumKeyExA at advapi32.dll stdcall';
function RegQueryInfoKey(hKey: Integer;lpClass: Integer; var lpcClass: Integer; lpReserved: Integer; var lpcSubKeys: Integer; var lpcMaxSubkeyLen: Integer; var lpcMaxClassLen: Integer; var lpcValues: Integer; var lpcMaxValueNameLen: Integer; var lpcMaxValueLen: Integer; var lpcbSecurityDescriptor: Integer; lpftLastWriteTime: Integer): Integer; external 'RegQueryInfoKeyA at advapi32.dll stdcall';
// End external functions
// From winerror.h/windows.pas:
Const KEY_QUERY_VALUE = $1;
Const KEY_ENUMERATE_SUB_KEYS = $8;
Const ERROR_SUCCESS = 0;
Const ERROR_MORE_DATA = 234;
Const ERROR_NO_MORE_ITEMS = 259;
// What this is all about:
// Created by Ton Huisman, Aug 2002 ath at ath.myweb.nl
// Freeware, no claims, no f(l)ames, use at your own risk, test before releasing to public!!
// RegKeyExists: Query for the existence of some Keyvalue in the registry
// -> Function RegKeyExists(RootKey : Integer; SubKey : String) : Boolean;
// Input : RootKey : A predefined value for the registryhive we want to query, like HKLM etc.
// SubKey : The full path to the queried key
// Output: Boolean: True if found, False if not found.
// Queried by trying to open the key for read access, True if successful
// Uses: RegOpenKeyEx, CastPtrToInt, RegCloseKey
// RegOpenKey: Open a Keyvalue in the registry
// -> Function RegOpenKey(RootKey : Integer; SubKey : String;Sam: Integer) : Integer;
// Sam : The Security Acces Mask, If 0 then KEY_QUERY_VALUE
// Output: Integer (HKey): Handle for registry key, 0 if not Ok
// RegKeyNames: Query for a string of all SubKeys of a SubKey in the registry
// -> Function RegKeyNames(RootKey: Integer; SubKey : String) : String;
// Output: String: Comma-separated list of all subkeys found
// Uses: RegOpenKey, CastIntToPtrStr, RegEnumKeyEx, RegCloseKey
// Supporting function
procedure MsgShow(c:string);
begin
MsgBox(c,mbConfirmation,MB_OK);
end;
Function CastPtrToInt(PtrStr: String) : Integer;
Begin
Result := Ord(StrGet(PtrStr,1)) + (Ord(StrGet(PtrStr,2)) * 256) + (Ord(StrGet(PtrStr,3))*256*256) + (Ord(StrGet(PtrStr,4))*256*256*256);
End; { CastPtrToInt }
// Cast Integer to PointerString
Function CastIntToPtrStr(Inte: Cardinal) : String;
Var n : Integer;
r : Cardinal;
t : Cardinal;
Begin
Result := StringOfChar(#0,4);
r := Inte;
n := 4;
If r >= (256*256*256) then
Begin
t := r / (256*256*256);
StrSet(Chr(t),n,Result);
r := r - (t * (256*256*256));
End;
n := n - 1;
If r >= (256*256) then
Begin
t := r / (256*256);
r := r - (t * (256*256));
End;
n := n - 1;
If r >= (256) then
Begin
t := r / (256);
r := r - (t * (256));
End;
n := n - 1;
If r > 0 then
Begin
t := r;
r := r - t;
End;
End; { CastIntToPtrStr }
Var l : Integer;
ls : String;
hKey : Integer;
Begin
ls := StringOfChar(#0,4);
l := CastStringToInteger(ls);
Result := (RegOpenKeyEx(RootKey,SubKey,0,KEY_QUERY_VALUE,l) = 0);
hKey := CastPtrToInt(ls);
RegCloseKey(hKey);
End; { RegKeyExists }
Var l : Integer;
ls : String;
Begin
If Sam = 0 then Sam := KEY_QUERY_VALUE;
Result := 0;
If (RegOpenKeyEx(RootKey,SubKey,0,Sam,l) = 0) then
Result := CastPtrToInt(ls);
End; { RegOpenKey }
Const Key_Separator = ',';// Default to comma, change as needed, could be #9 or ';'?
Const Key_MaxLength = 255;// Usually this (255) is way to large, 64 could do niceley, but just be safe. Longer keys than this length will be ignored!
Var hKey : Integer;// HKey is not directly supported...
wdIndex : Integer;
s : String;
ss : Integer;
st : String;
r : Integer;
Begin
wdIndex := 0;
Result := '';
s := StringOfChar(#0,Key_MaxLength);
ss := Key_MaxLength;
st := CastIntToPtrStr(ss);
hKey := RegOpenKey(RootKey,SubKey,KEY_QUERY_VALUE + KEY_ENUMERATE_SUB_KEYS);
If hKey <> 0 then
Begin
r := RegEnumKeyEx(hKey,wdIndex,s,st,0,'',0,0);
MsgBox('got ' + InttoStr(r), mbInformation, MB_OK);
While ((r = ERROR_SUCCESS) or (r = ERROR_MORE_DATA)) do
Begin
ss := CastPtrToInt(st);
If ss > 0 then begin
MsgBox(s, mbInformation, MB_OK);
Result := Result + Copy(s,1,ss) + Key_Separator;
end;
wdIndex := wdIndex + 1;
End;
If Result <> '' then
Result := Copy(Result,1,Length(Result) - 1);// remove extra separator ;-)
RegCloseKey(hKey);
End;
End; { RegKeyNames }
Function RegKeyNamesArray(RootKey: Integer; SubKey : String) : TArrayOfString;
Var hKey : Integer; // HKey is not directly supported...
SubKeys : Integer;
MaxSubkeyLen : Integer;
ActSubkeyLen : Integer;
ClassBufferSize : Integer;
MaxClassLen : Integer;
NumValues : Integer;
MaxValueNameLen : Integer;
MaxValueLen : Integer;
SecDescrLen : Integer;
SubkeyName, st : String;
ii : Integer;
jj : Integer;
Flag : Integer;
Res : TArrayOfString;
r, l : Integer;
Begin
SubKeys := 0;
MaxSubkeyLen := 0;
ClassBufferSize := 0;
MaxClassLen := 0;
NumValues := 0;
MaxValuenameLen := 0;
MaxValueLen := 0;
SecDescrLen := 0;
Flag := 0;
SetArrayLength(Res,0);
If hKey <> 0 then
Begin
// String zum Empfang der Subkey Anzahl vorbereiten
SubKeys := 0;
MaxSubkeyLen := 0;
r := RegQueryInfoKey(hKey,0,ClassBufferSize,0,SubKeys,MaxSubkeyLen,MaxClassLen,NumValues,MaxValuenameLen,MaxValueLen,SecDescrLen,0);
// MsgShow('RegQueryInfoKey: SubKeys = ' + IntToStr(SubKeys) + ' MaxSubkeylen = ' + IntToStr(MaxSubkeyLen));
SetArrayLength(Res,SubKeys);
for ii:=0 to (SubKeys-1) do
begin
ActSubkeyLen := MaxSubkeyLen + 1;
SubkeyName := StringOfChar(#0,ActSubkeyLen);
st := CastIntToPtrStr(ActSubkeyLen);
r := RegEnumKeyEx(hKey,ii,SubkeyName,st,0,'',0,0);
l := CastPtrToInt(st)
Res[ii] := Copy(SubkeyName, 0, l);
// MsgShow('RegEnumKeyEx returns SubkeyName = ' + Res[ii] + ' len is ' + IntToStr(l));
end;
End;
Result := Res;
End; { RegKeyNamesArray }
function InitializeSetup(): Boolean;
var
numPythons, i : Integer;
base, val : String;
begin
PythonKeyNames := RegKeyNamesArray(HKLM, 'Software\Python\PythonCore');
numPythons := GetArrayLength(PythonKeyNames);
//MsgShow('numpys ' + IntToStr(numPythons));
if numPythons > 1 then
MultiplePythonInstalls := true
else
MultiplePythonInstalls := false;
SetArrayLength(PythonPaths, numPythons);
SetArrayLength(PythonNames, numPythons);
SetArrayLength(PythonPathVals, numPythons);
for i := 0 to numPythons - 1 do
begin
base := 'Software\Python\PythonCore\' + PythonKeyNames[i] + '\InstallPath'
// MsgShow('base is <' + base+ '>');
RegQueryStringValue(HKLM, base, '', val)
PythonPaths[i] := val
RegQueryStringValue(HKLM, base + '\InstallGroup', '', val)
PythonNames[i] := val
end
{ Default to the latest one. }
PythonPathVals[numPythons - 1] := '1';
Result := true;
end;
function ScriptDlgPages(CurPage: Integer; BackClicked: Boolean): Boolean;
var
I, CurSubPage: Integer;
Nextt, NextOk: Boolean;
pythonPath: String;
begin
if (not BackClicked and (CurPage = wpSelectDir)) or (BackClicked and (CurPage = wpSelectProgramGroup)) then begin
{ Insert a custom wizard page between two non custom pages }
{ First open the custom wizard page }
ScriptDlgPageOpen();
{ Set some captions }
ScriptDlgPageSetCaption('Choose python version.');
ScriptDlgPageSetSubCaption1('Multiple versions of Python are installed on this system.');
ScriptDlgPageSetSubCaption2('Select the version you wish to use for the Access Grid Toolkit, and click Next.');
Nextt := InputOptionArray(PythonNames, PythonPathVals, True, False);
for i := 0 to GetArrayLength(PythonPathVals) - 1 do begin
if (PythonPathVals[i] = '1') then begin
pythonPath := PythonPaths[i];
break
end;
end;
MsgBox(pythonPath, mbInformation, MB_OK);
if not BackClicked then
Result := Nextt
else
Result := not Nextt;
ScriptDlgPageClose(not Result);
end else begin
Result := true
end;
end;
function NextButtonClick(CurPage: Integer): Boolean;
begin
if MultiplePythonInstalls then
Result := ScriptDlgPages(CurPage, False)
else
Result := True
end;
function BackButtonClick(CurPage: Integer): Boolean;
begin
Result := ScriptDlgPages(CurPage, True)
else
Result := True
end;
