fyi, cert/otherlowlevel to-dos
Robert Olson
olson at mcs.anl.gov
Mon Sep 22 16:59:35 CDT 2003
Fix pyGlobus.utilsc setenv/unsetenv so they compile properly on linux
again
fix network init stuff to properly handle machine hostnames that
resolve to mutiple IPs, some of which aren't active
fix network stuff to work properly without bringing up network init gui.
fix globus stuff to work properly on new-user init without bringing up
globus init gui.
remove proxy certs properly when default cert changed or is removed.
overhaul of error handling on grid-proxy-init
fix rh9 cert-req crashes
add more sanity-checking of cert hierarchy on startup (though the
timecheck fixes as added today may address the problems I thought were in
this).
--bob
