[Fwd: what gives with fl-caserver sending mail to test?]
Ti Leggett
leggett at mcs.anl.gov
Fri Sep 12 13:59:43 CDT 2003
fl-caserver should not be sending mail to test at mcs.anl.gov. If you're
testing something you should use the email address nobody at mcs.anl.gov.
-----Forwarded Message-----
> From: Gene Rackow <rackow at mcs.anl.gov>
> To: leggett at mcs.anl.gov
> Subject: what gives with fl-caserver sending mail to test?
> Date: 12 Sep 2003 13:56:42 -0500
> ------- Forwarded Message
> Return-Path: <owner-test at mcs.anl.gov>
> Received: (from listserv at localhost)
> by mcs.anl.gov (8.11.6/8.9.3) id h8CIq5T259878;
> Fri, 12 Sep 2003 13:52:05 -0500
> Date: Fri, 12 Sep 2003 13:52:05 -0500
> From: owner-test at mcs.anl.gov
> Message-Id: <200309121852.h8CIq5T259878 at mcs.anl.gov>
> To: rackow at mcs.anl.gov
> Subject: BOUNCE test at mcs.anl.gov: Non-member submission from [root at fl-caserver.mcs.anl.gov]
> X-Spam-Status: No, hits=1.1 required=5.0 tests=NO_REAL_NAME,X_NOT_PRESENT version=2.21
> X-Spam-Level: *
> Received: from fl-caserver.mcs.anl.gov (fl-caserver.mcs.anl.gov [140.221.9.174])
> by mcs.anl.gov (8.11.6/8.9.3) with ESMTP id h8CIq2P290690
> for <test at mcs.anl.gov>; Fri, 12 Sep 2003 13:52:02 -0500
> From: root at fl-caserver.mcs.anl.gov
> Received: (from root at localhost)
> by fl-caserver.mcs.anl.gov (8.11.6/8.9.1) id h8CIq2v03717
> for test at mcs.anl.gov; Fri, 12 Sep 2003 13:52:02 -0500
> Date: Fri, 12 Sep 2003 13:52:02 -0500
> Message-Id: <200309121852.h8CIq2v03717 at fl-caserver.mcs.anl.gov>
> To: test at mcs.anl.gov
> Subject: AG Dev Certificate Denied
> X-Spam-Level: *
> You're certificate request to the AG Developers CA has been denied. Please resubmit your request correcting the error described below. The reason for denying the request is: test
> ------- End of Forwarded Message
