PyMash
Rick Stevens
stevens at mcs.anl.gov
Tue Sep 9 17:24:29 CDT 2003
cool.
On Thu, 4 Sep 2003, Hiroyuki Komatsu wrote:
> I wrote a prototype of a python wrapper for OpenMash. The atteched
> file <mash-code_pymash-5.2.diff> is the diff file for
> <http:///www.openmash.org/download/5.2/mash-src-5.2.tar.gz>.
> [Sample Code]
> I replaced headlessVideo.mash by Chris to a python code as a sample.
> (For the replacement, I had the great help of Chris. Thanks!)
> Here is the core of the sample:
> from openmash import OpenMash
> from openmash_VideoAgent import VideoAgent
> from openmash_VideoPipeline import VideoPipeline
> class HeadlessVideo:
> def __init__(self, host, port, ttl = 16, key = None):
> self.agent = VideoAgent(host, port, ttl)
> self.pipeline = VideoPipeline(self.agent)
> if key is not None:
> self.agent.install_key(key)
> def run (self, device_number, codec):
> devices = self.pipeline.get_input_devices()
> self.pipeline.select(devices[device_number], codec)
> self.pipeline.start()
> def enhance (self, channel = None, format = None, bps = None,
> fps = None, quality = None):
> self.pipeline.set_options(port = channel, norm = format, bps = bps,
> fps = fps, quality = quality)
> def main(self, *args):
> headless_video = HeadlessVideo(self.host, self.port, self.ttl,
> self.key)
> headless_video.run(self.device_number, self.codec)
> headless_video.enhance(channel = self.channel,
> format = self.format,
> bps = self.bps,
> fps = self.fps,
> quality = self.quality)
> while True:
> OpenMash.update()
> time.sleep(0.1)
> <mash-code>/mash/python/example/headless.py is the whole code.
> [Requirement to Complie]
> SWIG
> AutoTools (autoconf)
> Python ;-)
> [How to Complile]
> 1. Patch this patch.
> % cd <mash-code>
> % patch -p1 < <mash-code_pymash-5.2.diff
> 2. Complie other source trees except mash.
> % build tcl
> % build tk
> % build otcl
> % build tclcl
> % build gsm
> % build srm
> 3. Create configure file in mash directory.
> % cd mash
> % autoconf
> 4. Create pymash
> % ./configure --disable-devel --python-includedir=<include dir for python>
> % make pymash
> On my environment (Linux/Debin), python-includedir is
> </usr/include/python2.3>
> [How to Test]
> % cd <mash-code>/mash/python
> % TCLCL_IMPORT_DIRS=.. python example/headless.py 127.0.0.1 9886 -d0 &
> % vic 127.0.0.1/9886
> The vic would probably display test transmission from headless.py.
> [How to Install]
> Not implemented yet.
> The current PyMash is based on smash (ie. non-Tk version).
> So, as a next step, I am going to modify PyMash to handle Tk or
> another window tool kit like WxPython. And then, I have a plan to
> write a vic-clone in Python.
> No more Tcl.
> Hiro
