Fwd: Re: let me know if you get this, or who should be.
Robert Olson
olson at mcs.anl.gov
Fri Oct 10 13:20:34 CDT 2003
>X-Authentication-Warning: frodo.mcs.anl.gov: rackow owned process doing -bs
>To: Robert Olson <olson at mcs.anl.gov>
>cc: root at fl-caserver.mcs.anl.gov
>Subject: Re: let me know if you get this, or who should be.
>X-message-flag: "Outlook not so good." Wow, that magic 8-ball really DOES
>work!
>X-Request-Do: take
>X-Request-Do: Resolve
>X-Spam-Status: No
>Date: Fri, 10 Oct 2003 13:14:31 -0500
>From: Gene Rackow <rackow at mcs.anl.gov>
>X-Whitelist-by-bob: yes
>Except that is currently a restricted_post list to just list members.
>If that is to be opened for replies to this, I can easily reset that.
>It would be nice of the email being sent from that machine was made
>to appear as if the message was coming from a real address that could be
>replied to. "root at fl-ca.." was set to == "root at mcs", which really
>is not right.
>I have not looked at it, but it if suspicions are correct then
>the stuff sending this out is running as root. It would be better
>if it was running as some restricted user, that way IF someone decided to
>attack the machine, their chances of root exploit are much smaller.
>I'm not sure how or if that is possible on that machine or app...
>Just somethign to consider.
>-_Gene
>Robert Olson made the following keystrokes:
> >I got it ... probably should go to agdev-ca at mcs.
> >thanks,
> >--bob
> >>-_gene
> >>------- Forwarded Message
> >>Return-Path: <lthg at ncsa.uiuc.edu>
> >>Received: from mail.ncsa.uiuc.edu (mail.ncsa.uiuc.edu [141.142.2.28])
> >> by mcs.anl.gov (8.11.6/8.9.3) with ESMTP id h9AHbS6309346
> >> for <root at fl-caserver.mcs.anl.gov>; Fri, 10 Oct 2003 12:37:28
> -0500
> >>X-Envelope-From: lthg at ncsa.uiuc.edu
> >>X-Envelope-To: <root at fl-caserver.mcs.anl.gov>
> >>Received: from EOT-PC-03.ncsa.uiuc.edu (eot-pc-03.ncsa.uiuc.edu
> >>[141.142.104.46])
> >> by mail.ncsa.uiuc.edu (8.11.6p2/8.11.6) with ESMTP id
> h9AHbHI09993
> >> for <root at fl-caserver.mcs.anl.gov>; Fri, 10 Oct 2003 12:37:19
> -0500
> >>Message-Id: <5.2.0.9.2.20031010123613.00a73c40 at pop.ncsa.uiuc.edu>
> >>X-Sender: lthg at pop.ncsa.uiuc.edu (Unverified)
> >>X-Mailer: QUALCOMM Windows Eudora Version 5.2.0.9
> >>Date: Fri, 10 Oct 2003 12:37:02 -0500
> >>To: root at fl-caserver.mcs.anl.gov
> >>From: Johnson Ling <lthg at ncsa.uiuc.edu>
> >>Subject: Re: AG Dev Certificate Approved
> >>In-Reply-To: <200310061948.h96JmjB25741 at fl-caserver.mcs.anl.gov>
> >>Mime-Version: 1.0
> >>Content-Type: text/plain; charset="us-ascii"; format=flowed
> >>X-Spam-Status: No, hits=-1.0 required=5.0
> >> tests=EMAIL_ATTRIBUTION,IN_REP_TO
> >> version=2.55
> >>X-Spam-Level:
> >>X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
> >>Hi,
> >>I think I delete the certificate in accident. Can I request once more?
> >>Johnson
> >>At 02:48 PM 10/6/2003 -0500, you wrote:
> >> >Your certificate request to the AG Developers CA has been approved and
> >> >your certificate is ready. You can retrieve this certificate
> automatically
> >> >by running the Venues Client and picking View Pending requests from the
> >> >Preferences->Manage Certificates Menu.
> >>------- End of Forwarded Message
