FW: mboned: UMTP 'last mile' multicast tunneling agents again available for trial
Ivan R. Judson
judson at mcs.anl.gov
Tue Nov 4 20:19:10 CST 2003
This is a good trial to see why I want to finish the umtp implementation
I've already started adding to the ucl common library.
--Ivan
> -----Original Message-----
> From: owner-mboned at lists.uoregon.edu
> [mailto:owner-mboned at lists.uoregon.edu] On Behalf Of Ross Finlayson
> Sent: Tuesday, November 04, 2003 7:59 PM
> To: mboned at network-services.uoregon.edu; wg-multicast at internet2.edu
> Subject: mboned: UMTP 'last mile' multicast tunneling agents
> Once again, I'm making available - for the remainder of this
> month - trial
> versions of my UMTP tunneling agents: "liveGate" and
> "liveGateForIntranets". (These will allow you to, for
> example, watch the
> upcoming IETF multicast sessions from a non-MBone-connected network.)
> You set up a tunnel by running two tunnel endpoints:
> 1/ On a computer that's **already on the MBone** (preferably
> a computer
> that's topologically close to you), download and run "liveGate":
> http://www.live.com/liveGate/
> Configure this using the instructions in:
> http://www.live.com/liveGate/configuration.html
> 2/ On a computer that's **not** on the MBone (e.g., your home
> PC, or a
> server on your (non-MBone-accessible) LAN, download and run
> "liveGateForIntranets":
> http://www.live.com/lgfi4408/
> http://www.live.com/lgfi4408/configuration.html
> For example, the following "liveGateInit" file (for
> "liveGateForIntranets")
> can be used to receive the upcoming IETF MBone sessions
> <http://videolab.uoregon.edu/events/ietf/ietf58.html>:
> ##### Sample "liveGateInit" file for "liveGateForIntranets"
> ##### liveGate_createTunnel
> <name-or-IP-address-of-your-remote-liveGate-server>
> proc ietf_c1_h261 {} {
> liveGate_startRelayingRTP 224.0.1.12 61010 127 ;# video
> liveGate_startRelayingRTP 224.0.1.11 21010 127 ;# audio
> proc ietf_c1_mpeg1 {} {
> liveGate_startRelayingRTP 224.2.128.17 61030 127 ;# video
> liveGate_startRelayingRTP 224.2.128.16 21030 127 ;#
> audio } proc ietf_c1_mpeg4 {} {
> liveGate_startRelayingRTP 224.2.195.59 49470 127 ;# video
> liveGate_startRelayingRTP 224.2.166.105 19154 127 ;#
> audio } proc ietf_c2_h261 {} {
> liveGate_startRelayingRTP 224.0.1.15 61020 127 ;# video
> liveGate_startRelayingRTP 224.0.1.14 21020 127 ;# audio
> proc ietf_c2_mpeg1 {} {
> liveGate_startRelayingRTP 224.2.128.19 61040 127 ;# video
> liveGate_startRelayingRTP 224.2.128.18 21040 127 ;#
> audio } proc ietf_c2_mpeg4 {} {
> liveGate_startRelayingRTP 224.2.168.177 64390 127 ;# video
> liveGate_startRelayingRTP 224.2.134.163 28132 127 ;# audio }
> # Then, to start relaying the "IETF channel 1 H.261 session
> (e.g.)", do: ietf_c1_h261 # (Repeat as appropriate to relay
> other sessions) ##### End of sample "liveGateInit" file for
> "liveGateForIntranets" #####
> Ross.
> ps. For more information about UMTP (the multicast tunneling
> protocol), see
> <http://www.live.com/umtp.txt>
> __________________________________________________________
> web archive: http://darkwing.uoregon.edu/~llynch/mboned/
