Can't connect to my own VenueServer
Ti Leggett
leggett at mcs.anl.gov
Tue May 20 11:26:00 CDT 2003
Attached are my log files. And here's the error VenueServer.py spits out
when I try to close it:
Server URL: https://scraz.mcs.anl.gov:8000/VenueServer
Event Port: 8002 Text Port: 8004 Data Port: 8006
Got Signal!!!!
Traceback (most recent call last):
File "/usr/bin/VenueServer.py", line 164, in ?
time.sleep(1)
File "/usr/bin/VenueServer.py", line 44, in SignalHandler
venueServer.Shutdown(0)
TypeError: Shutdown() takes exactly 1 argument (2 given)
05/20/2003 10:10:47 AM DEBUG My hostname is scraz.mcs.anl.gov
05/20/2003 10:10:47 AM DEBUG VerifyExecutionEnvironment: bind to local hostname of scraz.mcs.anl.gov succeeds
05/20/2003 10:10:47 AM DEBUG userConfigDir: /home/leggett/.AccessGrid
05/20/2003 10:10:47 AM DEBUG using existing configuration
05/20/2003 10:10:47 AM DEBUG CertificateRepository: scanning /home/leggett/.AccessGrid/identity_certificates
05/20/2003 10:10:47 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett
05/20/2003 10:10:47 AM DEBUG CertificateRepository: scanning /etc/grid-security/certificates
05/20/2003 10:10:47 AM DEBUG Loaded certificate for /C=US/O=Globus/CN=Globus Certification Authority
05/20/2003 10:10:47 AM DEBUG Loaded certificate for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
05/20/2003 10:10:47 AM DEBUG Checking that default dn /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett has a certificate
05/20/2003 10:10:47 AM DEBUG InitEnvironment: using standard proxy setup
05/20/2003 10:10:47 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett/CN=proxy
05/20/2003 10:10:47 AM DEBUG Proxy /tmp/x509_up_leggett is valid
05/20/2003 10:10:47 AM DEBUG Set X509_USER_PROXY to /tmp/x509_up_leggett
05/20/2003 10:10:47 AM DEBUG Set X509_CERT_DIR to /etc/grid-security/certificates
05/20/2003 10:10:47 AM DEBUG bin.VenueClient::__createPersonalDataStore: Creating personal datastore at /home/leggett/.AccessGrid/personalDataStore using prefix personalDataStore and port 9999
05/20/2003 10:10:47 AM DEBUG Datastore path is /home/leggett/.AccessGrid/personalDataStore
05/20/2003 10:10:47 AM DEBUG Worker 0 starting
05/20/2003 10:10:47 AM DEBUG bin.VenueClient::__createPersonalDataStore: Load personal data from file
05/20/2003 10:10:47 AM DEBUG bin.VenueClient::__createPersonalDataStore: Personal data dict: {}
05/20/2003 10:10:47 AM INFO Applications dir = /etc/AccessGrid/applications
05/20/2003 10:10:48 AM DEBUG bin.VenueClient::OnInit: ispersonal=0
05/20/2003 10:10:48 AM DEBUG bin.VenueClient::__startMainLoop: start wxApp main loop/thread
05/20/2003 10:11:05 AM DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://scraz.mcs.anl.gov:8000/VenueServer
05/20/2003 10:11:05 AM DEBUG Set history url: None
05/20/2003 10:11:05 AM DEBUG bin.VenueClient::EnterVenue: server url: https://scraz.mcs.anl.gov:8000/Venues/000000f5461da9c3007f000000000001aba
05/20/2003 10:11:07 AM ERROR bin.VenueClient::EnterVenue failed
File "/usr/bin/VenueClient.py", line 545, in EnterVenue
warningString = VenueClient.EnterVenue( self, URL )
File "/usr/lib/python2.2/site-packages/AccessGrid/VenueClient.py", line 230, in EnterVenue
(venueState, self.privateId, streamDescList ) = Client.Handle( URL ).get_proxy().Enter( self.profile )
File "/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.py", line 3650, in __call__
return self.__r_call(*args, **kw)
File "/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.py", line 3670, in __r_call
self.__hd, self.__ma)
File "/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.py", line 3585, in __call
raise p
faultType: <Fault SOAP-ENV:Client: No method Enter found>
05/20/2003 10:11:50 AM INFO --------- END VenueClient
05/20/2003 10:11:50 AM DEBUG exit venue
05/20/2003 10:11:50 AM INFO VenueClient.ExitVenue
05/20/2003 10:11:50 AM ERROR AccessGrid.VenueClient::ExitVenue exception
File "/usr/lib/python2.2/site-packages/AccessGrid/VenueClient.py", line 395, in ExitVenue
self.venueProxy.Exit( self.privateId )
AttributeError: 'NoneType' object has no attribute 'Exit'
05/20/2003 10:11:50 AM INFO Stopping event client
05/20/2003 10:11:50 AM INFO Stopping node services
05/20/2003 10:11:51 AM ERROR Exception stopping node services
File "/usr/lib/python2.2/site-packages/AccessGrid/VenueClient.py", line 420, in ExitVenue
Client.Handle(self.nodeServiceUri).GetProxy().SetStreams([])
File "/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/AGGSISOAP.py", line 3570, in __call
config = self.config)
File "/usr/lib/python2.2/site-packages/AccessGrid/hosting/pyGlobus/Client.py", line 180, in call
r.endheaders()
File "//usr/lib/python2.2/httplib.py", line 695, in endheaders
self._send_output()
File "//usr/lib/python2.2/httplib.py", line 581, in _send_output
self.send(msg)
File "//usr/lib/python2.2/httplib.py", line 548, in send
self.connect()
File "/usr/lib/python2.2/site-packages/pyGlobus/io.py", line 1074, in connect
self.sock.connect(self.host, self.port, self.io_attr)
File "/usr/lib/python2.2/site-packages/pyGlobus/io.py", line 655, in connect
ret, handle = ioc.tcp_connect(host, port, attr.get_handle())
KeyboardInterrupt
05/20/2003 10:11:51 AM DEBUG Worker 0 gets cmd quit
05/20/2003 10:11:51 AM DEBUG Worker 0 exiting
05/20/2003 10:11:51 AM INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
05/20/2003 10:50:28 AM DEBUG My hostname is scraz.mcs.anl.gov
05/20/2003 10:50:28 AM DEBUG VerifyExecutionEnvironment: bind to local hostname of scraz.mcs.anl.gov succeeds
05/20/2003 10:50:28 AM DEBUG userConfigDir: /home/leggett/.AccessGrid
05/20/2003 10:50:28 AM DEBUG using existing configuration
05/20/2003 10:50:28 AM DEBUG CertificateRepository: scanning /home/leggett/.AccessGrid/identity_certificates
05/20/2003 10:50:28 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett
05/20/2003 10:50:28 AM DEBUG CertificateRepository: scanning /etc/grid-security/certificates
05/20/2003 10:50:28 AM DEBUG Loaded certificate for /C=US/O=Globus/CN=Globus Certification Authority
05/20/2003 10:50:28 AM DEBUG Loaded certificate for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
05/20/2003 10:50:28 AM DEBUG Checking that default dn /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett has a certificate
05/20/2003 10:50:28 AM DEBUG InitEnvironment: using standard proxy setup
05/20/2003 10:50:28 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett/CN=proxy
05/20/2003 10:50:28 AM DEBUG Proxy /tmp/x509_up_leggett is valid
05/20/2003 10:50:28 AM DEBUG Set X509_USER_PROXY to /tmp/x509_up_leggett
05/20/2003 10:50:28 AM DEBUG Set X509_CERT_DIR to /etc/grid-security/certificates
05/20/2003 10:50:28 AM DEBUG bin.VenueClient::__createPersonalDataStore: Creating personal datastore at /home/leggett/.AccessGrid/personalDataStore using prefix personalDataStore and port 9999
05/20/2003 10:50:28 AM DEBUG Datastore path is /home/leggett/.AccessGrid/personalDataStore
05/20/2003 10:50:28 AM DEBUG Worker 0 starting
05/20/2003 10:50:28 AM DEBUG bin.VenueClient::__createPersonalDataStore: Load personal data from file
05/20/2003 10:50:28 AM DEBUG bin.VenueClient::__createPersonalDataStore: Personal data dict: {}
05/20/2003 10:50:28 AM INFO Applications dir = /etc/AccessGrid/applications
05/20/2003 10:50:28 AM DEBUG bin.VenueClient::OnInit: ispersonal=0
05/20/2003 10:50:28 AM DEBUG bin.VenueClient::__startMainLoop: start wxApp main loop/thread
05/20/2003 10:50:36 AM DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://scraz.mcs.anl.gov:8000/VenueServer
05/20/2003 10:50:36 AM DEBUG Set history url: None
05/20/2003 10:50:38 AM ERROR bin.VenueClient::EnterVenue failed
File "/usr/bin/VenueClient.py", line 616, in EnterVenue
raise p
05/20/2003 10:51:19 AM INFO --------- END VenueClient
05/20/2003 10:51:19 AM DEBUG Worker 0 gets cmd quit
05/20/2003 10:51:19 AM DEBUG Worker 0 exiting
05/20/2003 10:51:19 AM INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
05/20/2003 11:09:04 AM DEBUG My hostname is scraz.mcs.anl.gov
05/20/2003 11:09:04 AM DEBUG VerifyExecutionEnvironment: bind to local hostname of scraz.mcs.anl.gov succeeds
05/20/2003 11:09:04 AM DEBUG userConfigDir: /home/leggett/.AccessGrid
05/20/2003 11:09:04 AM DEBUG using existing configuration
05/20/2003 11:09:04 AM DEBUG CertificateRepository: scanning /home/leggett/.AccessGrid/identity_certificates
05/20/2003 11:09:04 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett
05/20/2003 11:09:04 AM DEBUG CertificateRepository: scanning /etc/grid-security/certificates
05/20/2003 11:09:04 AM DEBUG Loaded certificate for /C=US/O=Globus/CN=Globus Certification Authority
05/20/2003 11:09:04 AM DEBUG Loaded certificate for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
05/20/2003 11:09:04 AM DEBUG Checking that default dn /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett has a certificate
05/20/2003 11:09:04 AM DEBUG InitEnvironment: using standard proxy setup
05/20/2003 11:09:04 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett/CN=proxy
05/20/2003 11:09:04 AM DEBUG Proxy /tmp/x509_up_leggett is valid
05/20/2003 11:09:04 AM DEBUG Set X509_USER_PROXY to /tmp/x509_up_leggett
05/20/2003 11:09:04 AM DEBUG Set X509_CERT_DIR to /etc/grid-security/certificates
05/20/2003 11:09:04 AM DEBUG bin.VenueClient::__createPersonalDataStore: Creating personal datastore at /home/leggett/.AccessGrid/personalDataStore using prefix personalDataStore and port 9999
05/20/2003 11:09:04 AM DEBUG Datastore path is /home/leggett/.AccessGrid/personalDataStore
05/20/2003 11:09:04 AM DEBUG bin.VenueClient::__createPersonalDataStore: Load personal data from file
05/20/2003 11:09:04 AM DEBUG Worker 0 starting
05/20/2003 11:09:04 AM DEBUG bin.VenueClient::__createPersonalDataStore: Personal data dict: {}
05/20/2003 11:09:04 AM INFO Applications dir = /etc/AccessGrid/applications
05/20/2003 11:09:04 AM DEBUG bin.VenueClient::OnInit: ispersonal=0
05/20/2003 11:09:04 AM DEBUG bin.VenueClient::__startMainLoop: start wxApp main loop/thread
05/20/2003 11:09:15 AM DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://scraz.mcs.anl.gov:8000/VenueServer
05/20/2003 11:09:15 AM DEBUG Set history url: None
05/20/2003 11:09:16 AM ERROR bin.VenueClient::EnterVenue failed
raise p
05/20/2003 11:09:21 AM INFO --------- END VenueClient
05/20/2003 11:09:21 AM DEBUG Worker 0 gets cmd quit
05/20/2003 11:09:21 AM DEBUG Worker 0 exiting
05/20/2003 11:09:21 AM INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
05/20/2003 11:09:57 AM DEBUG My hostname is scraz.mcs.anl.gov
05/20/2003 11:09:57 AM DEBUG VerifyExecutionEnvironment: bind to local hostname of scraz.mcs.anl.gov succeeds
05/20/2003 11:09:57 AM DEBUG userConfigDir: /home/leggett/.AccessGrid
05/20/2003 11:09:57 AM DEBUG using existing configuration
05/20/2003 11:09:57 AM DEBUG CertificateRepository: scanning /home/leggett/.AccessGrid/identity_certificates
05/20/2003 11:09:57 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett
05/20/2003 11:09:57 AM DEBUG CertificateRepository: scanning /etc/grid-security/certificates
05/20/2003 11:09:57 AM DEBUG Loaded certificate for /C=US/O=Globus/CN=Globus Certification Authority
05/20/2003 11:09:57 AM DEBUG Loaded certificate for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
05/20/2003 11:09:57 AM DEBUG Checking that default dn /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett has a certificate
05/20/2003 11:09:57 AM DEBUG InitEnvironment: using standard proxy setup
05/20/2003 11:09:57 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett/CN=proxy
05/20/2003 11:09:57 AM DEBUG Proxy /tmp/x509_up_leggett is valid
05/20/2003 11:09:57 AM DEBUG Set X509_USER_PROXY to /tmp/x509_up_leggett
05/20/2003 11:09:57 AM DEBUG Set X509_CERT_DIR to /etc/grid-security/certificates
05/20/2003 11:09:57 AM DEBUG bin.VenueClient::__createPersonalDataStore: Creating personal datastore at /home/leggett/.AccessGrid/personalDataStore using prefix personalDataStore and port 9999
05/20/2003 11:09:57 AM DEBUG Datastore path is /home/leggett/.AccessGrid/personalDataStore
05/20/2003 11:09:57 AM DEBUG bin.VenueClient::__createPersonalDataStore: Load personal data from file
05/20/2003 11:09:57 AM DEBUG bin.VenueClient::__createPersonalDataStore: Personal data dict: {}
05/20/2003 11:09:57 AM DEBUG Worker 0 starting
05/20/2003 11:09:57 AM INFO Applications dir = /etc/AccessGrid/applications
05/20/2003 11:09:57 AM DEBUG bin.VenueClient::OnInit: ispersonal=0
05/20/2003 11:09:57 AM DEBUG bin.VenueClient::__startMainLoop: start wxApp main loop/thread
05/20/2003 11:09:59 AM DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
05/20/2003 11:09:59 AM DEBUG Set history url: None
05/20/2003 11:10:00 AM INFO Sending data: Event:
Type: Connect Venue: 000000f531b860bd008c00dd000b003705d Data: 000000f5465591f1008c00dd000b0037420
Type: Client Heartbeat Venue: 000000f531b860bd008c00dd000b003705d Data: 000000f5465591f1008c00dd000b0037420
05/20/2003 11:10:01 AM DEBUG clean up frame
05/20/2003 11:10:01 AM DEBUG Add participants
05/20/2003 11:10:01 AM DEBUG Ti Leggett
05/20/2003 11:10:01 AM DEBUG Add data
05/20/2003 11:10:01 AM DEBUG AG2ScreenShot1small.tif
05/20/2003 11:10:01 AM DEBUG Add service
05/20/2003 11:10:01 AM DEBUG Add application
05/20/2003 11:10:01 AM DEBUG Add exits
05/20/2003 11:10:01 AM DEBUG Additional Meeting Room Lobby
05/20/2003 11:10:01 AM DEBUG Secure Room
05/20/2003 11:10:01 AM DEBUG Bridgeport Room
05/20/2003 11:10:01 AM DEBUG Encryption Test Room
05/20/2003 11:10:01 AM DEBUG Test Room
05/20/2003 11:10:01 AM DEBUG Secure2
05/20/2003 11:10:01 AM DEBUG Big Horn Room
05/20/2003 11:10:01 AM DEBUG Jack Frost Room
05/20/2003 11:10:01 AM DEBUG Supercomputing 2002
05/20/2003 11:10:01 AM DEBUG Lucky Labrador Room
05/20/2003 11:10:01 AM DEBUG Windmer Room
05/20/2003 11:10:01 AM DEBUG Screening Room
05/20/2003 11:10:01 AM DEBUG Full Sail Room
05/20/2003 11:10:01 AM DEBUG Institution Lobby
05/20/2003 11:10:01 AM DEBUG Set text location and address bar
05/20/2003 11:10:02 AM DEBUG Get upload url https://vv2.mcs.anl.gov:9004/000000f531b860bd008c00dd000b003705d
05/20/2003 11:10:02 AM DEBUG Add your personal data descriptions to venue
05/20/2003 11:10:02 AM DEBUG Lead followers
05/20/2003 11:10:02 AM DEBUG Entered venue
05/20/2003 11:10:02 AM DEBUG profile.type = None
05/20/2003 11:10:02 AM DEBUG This is venue data
host:vv2.mcs.anl.gov
port:9006
venueId:000000f531b860bd008c00dd000b003705d
attr:<pyGlobus.io.TCPIOAttr instance at 0x8916e94>
socket:<pyGlobus.io.GSITCPSocket instance at 0x8980e24>
05/20/2003 11:10:02 AM INFO --------- START TextClient
05/20/2003 11:10:02 AM DEBUG EVENT --- Input
05/20/2003 11:10:02 AM DEBUG Event:
05/20/2003 11:10:02 AM DEBUG Process network
05/20/2003 11:10:05 AM INFO Sending data: Event:
05/20/2003 11:10:07 AM INFO --------- END VenueClient
05/20/2003 11:10:07 AM DEBUG exit venue
05/20/2003 11:10:07 AM INFO VenueClient.ExitVenue
05/20/2003 11:10:07 AM DEBUG EventClient: DataSize: 4
05/20/2003 11:10:07 AM DEBUG EventClient: Read size: 1955
05/20/2003 11:10:07 AM DEBUG EventClient: Read data.
05/20/2003 11:10:07 AM DEBUG Got Remove User Event
05/20/2003 11:10:07 AM INFO Stopping heartbeats
05/20/2003 11:10:07 AM INFO Stopping event client
05/20/2003 11:10:07 AM INFO Sending data: Event:
Type: Disconnect Venue: 000000f531b860bd008c00dd000b003705d Data: 000000f5465591f1008c00dd000b0037420
05/20/2003 11:10:07 AM INFO Stopping node services
05/20/2003 11:10:08 AM DEBUG Worker 0 gets cmd quit
05/20/2003 11:10:08 AM DEBUG Worker 0 exiting
05/20/2003 11:10:08 AM INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
05/20/2003 11:10:51 AM DEBUG My hostname is scraz.mcs.anl.gov
05/20/2003 11:10:51 AM DEBUG VerifyExecutionEnvironment: bind to local hostname of scraz.mcs.anl.gov succeeds
05/20/2003 11:10:51 AM DEBUG userConfigDir: /home/leggett/.AccessGrid
05/20/2003 11:10:51 AM DEBUG using existing configuration
05/20/2003 11:10:51 AM DEBUG CertificateRepository: scanning /home/leggett/.AccessGrid/identity_certificates
05/20/2003 11:10:51 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett
05/20/2003 11:10:51 AM DEBUG CertificateRepository: scanning /etc/grid-security/certificates
05/20/2003 11:10:51 AM DEBUG Loaded certificate for /C=US/O=Globus/CN=Globus Certification Authority
05/20/2003 11:10:51 AM DEBUG Loaded certificate for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
05/20/2003 11:10:51 AM DEBUG Checking that default dn /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett has a certificate
05/20/2003 11:10:51 AM DEBUG InitEnvironment: using standard proxy setup
05/20/2003 11:10:51 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett/CN=proxy
05/20/2003 11:10:51 AM DEBUG Proxy /tmp/x509_up_leggett is valid
05/20/2003 11:10:51 AM DEBUG Set X509_USER_PROXY to /tmp/x509_up_leggett
05/20/2003 11:10:51 AM DEBUG Set X509_CERT_DIR to /etc/grid-security/certificates
05/20/2003 11:10:51 AM DEBUG bin.VenueClient::__createPersonalDataStore: Creating personal datastore at /home/leggett/.AccessGrid/personalDataStore using prefix personalDataStore and port 9999
05/20/2003 11:10:51 AM DEBUG Datastore path is /home/leggett/.AccessGrid/personalDataStore
05/20/2003 11:10:51 AM DEBUG bin.VenueClient::__createPersonalDataStore: Load personal data from file
05/20/2003 11:10:51 AM DEBUG bin.VenueClient::__createPersonalDataStore: Personal data dict: {}
05/20/2003 11:10:51 AM DEBUG Worker 0 starting
05/20/2003 11:10:51 AM INFO Applications dir = /etc/AccessGrid/applications
05/20/2003 11:10:51 AM DEBUG bin.VenueClient::OnInit: ispersonal=0
05/20/2003 11:10:51 AM DEBUG bin.VenueClient::__startMainLoop: start wxApp main loop/thread
05/20/2003 11:11:03 AM DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://localhost:8000/VenueServer
05/20/2003 11:11:03 AM DEBUG Set history url: None
05/20/2003 11:11:04 AM ERROR bin.VenueClient::EnterVenue failed
raise p
05/20/2003 11:11:07 AM INFO --------- END VenueClient
05/20/2003 11:11:07 AM DEBUG Worker 0 gets cmd quit
05/20/2003 11:11:07 AM DEBUG Worker 0 exiting
05/20/2003 11:11:07 AM INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
05/20/2003 11:24:25 AM DEBUG My hostname is scraz.mcs.anl.gov
05/20/2003 11:24:25 AM DEBUG VerifyExecutionEnvironment: bind to local hostname of scraz.mcs.anl.gov succeeds
05/20/2003 11:24:25 AM DEBUG userConfigDir: /home/leggett/.AccessGrid
05/20/2003 11:24:25 AM DEBUG using existing configuration
05/20/2003 11:24:25 AM DEBUG CertificateRepository: scanning /home/leggett/.AccessGrid/identity_certificates
05/20/2003 11:24:25 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett
05/20/2003 11:24:25 AM DEBUG CertificateRepository: scanning /etc/grid-security/certificates
05/20/2003 11:24:25 AM DEBUG Loaded certificate for /C=US/O=Globus/CN=Globus Certification Authority
05/20/2003 11:24:25 AM DEBUG Loaded certificate for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
05/20/2003 11:24:25 AM DEBUG Checking that default dn /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett has a certificate
05/20/2003 11:24:25 AM DEBUG InitEnvironment: using standard proxy setup
05/20/2003 11:24:25 AM DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett/CN=proxy
05/20/2003 11:24:25 AM DEBUG Proxy /tmp/x509_up_leggett is valid
05/20/2003 11:24:25 AM DEBUG Set X509_USER_PROXY to /tmp/x509_up_leggett
05/20/2003 11:24:25 AM DEBUG Set X509_CERT_DIR to /etc/grid-security/certificates
05/20/2003 11:24:25 AM DEBUG bin.VenueClient::__createPersonalDataStore: Creating personal datastore at /home/leggett/.AccessGrid/personalDataStore using prefix personalDataStore and port 9999
05/20/2003 11:24:25 AM DEBUG Datastore path is /home/leggett/.AccessGrid/personalDataStore
05/20/2003 11:24:25 AM DEBUG bin.VenueClient::__createPersonalDataStore: Load personal data from file
05/20/2003 11:24:25 AM DEBUG Worker 0 starting
05/20/2003 11:24:25 AM DEBUG bin.VenueClient::__createPersonalDataStore: Personal data dict: {}
05/20/2003 11:24:25 AM INFO Applications dir = /etc/AccessGrid/applications
05/20/2003 11:24:25 AM DEBUG bin.VenueClient::OnInit: ispersonal=0
05/20/2003 11:24:25 AM DEBUG bin.VenueClient::__startMainLoop: start wxApp main loop/thread
05/20/2003 11:24:31 AM DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://scraz.mcs.anl.gov:8000/VenueServer
05/20/2003 11:24:31 AM DEBUG Set history url: None
05/20/2003 11:24:33 AM ERROR bin.VenueClient::EnterVenue failed
raise p
05/20/2003 11:24:35 AM INFO --------- END VenueClient
05/20/2003 11:24:35 AM DEBUG Worker 0 gets cmd quit
05/20/2003 11:24:35 AM DEBUG Worker 0 exiting
05/20/2003 11:24:35 AM INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
05/20/03 11:24:14 DEBUG userConfigDir: /home/leggett/.AccessGrid
05/20/03 11:24:14 DEBUG using existing configuration
05/20/03 11:24:14 DEBUG CertificateRepository: scanning /home/leggett/.AccessGrid/identity_certificates
05/20/03 11:24:14 DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett
05/20/03 11:24:14 DEBUG CertificateRepository: scanning /etc/grid-security/certificates
05/20/03 11:24:14 DEBUG Loaded certificate for /C=US/O=Globus/CN=Globus Certification Authority
05/20/03 11:24:14 DEBUG Loaded certificate for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
05/20/03 11:24:14 DEBUG Checking that default dn /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett has a certificate
05/20/03 11:24:14 DEBUG InitEnvironment: using standard proxy setup
05/20/03 11:24:14 DEBUG Loaded certificate for /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett/CN=proxy
05/20/03 11:24:14 DEBUG Proxy /tmp/x509_up_leggett is valid
05/20/03 11:24:14 DEBUG Set X509_USER_PROXY to /tmp/x509_up_leggett
05/20/03 11:24:14 DEBUG Set X509_CERT_DIR to /etc/grid-security/certificates
05/20/03 11:24:14 DEBUG VenueServer running as /O=Grid/O=Globus/OU=mcs.anl.gov/CN=Ti Leggett
05/20/03 11:24:14 DEBUG Event Service Started
05/20/03 11:24:14 DEBUG Text Service Started
05/20/03 11:24:14 INFO Venue URI https://scraz.mcs.anl.gov:8000/Venues/000000f546629b4d007f000000000001dea
05/20/03 11:24:14 DEBUG EventService: AddChannel 000000f546629b4d007f000000000001dea
05/20/03 11:24:14 DEBUG Text Service: Adding Channel: 000000f546629b4d007f000000000001dea
05/20/03 11:24:14 DEBUG Datastore path is Data/000000f546629b4d007f000000000001dea
05/20/03 11:24:14 INFO Have upload url: https://scraz.mcs.anl.gov:8006/000000f546629b4d007f000000000001dea
05/20/03 11:24:14 DEBUG EventService: Sending Event Event:
Type: Set connections Venue: 000000f546629b4d007f000000000001dea Data: []
05/20/03 11:24:14 DEBUG Worker 0 starting
05/20/03 11:24:14 DEBUG Worker 1 starting
05/20/03 11:24:14 DEBUG Worker 2 starting
05/20/03 11:24:14 DEBUG Worker 3 starting
05/20/03 11:24:14 DEBUG Worker 4 starting
05/20/03 11:24:14 DEBUG Event Service: Running
05/20/03 11:24:15 DEBUG Text Service: Running
05/20/03 11:24:15 DEBUG Starting Hosting Environment.
05/20/03 11:24:15 INFO Checkpointing completed at Tue May 20 11:24:15 2003.
05/20/03 11:24:45 INFO Checkpointing completed at Tue May 20 11:24:45 2003.
