New ag-rat, ag-vic, pyglobus/winglobus packages
Ti Leggett
leggett at mcs.anl.gov
Fri May 16 11:13:57 CDT 2003
I've just created new RPMS for AccessGrid-rat, AccessGrid-vic, and
pyGlobus. I've also created a new WinGlobus windows installer. They can
be found on a green machine at:
/mcs/www/fl/research/accessgrid/software/required/RPMS/AccessGrid-rat-4.2.22-2.i386.rpm
/mcs/www/fl/research/accessgrid/software/required/RPMS/AccessGrid-vic-2.8ucl1.1.3-3.i386.rpm
/mcs/www/fl/research/accessgrid/software/required/RPMS/pyGlobus-cvs-5.i386.rpm
/mcs/www/fl/research/accessgrid/software/required/windows/WinGlobus-2.0-7.exe
And SRPMS at
/mcs/www/fl/research/accessgrid/software/required/SRPMS/AccessGrid-rat-4.2.22-2.src.rpm
/mcs/www/fl/research/accessgrid/software/required/SRPMS/AccessGrid-vic-2.8ucl1.1.3-3.src.rpm
/mcs/www/fl/research/accessgrid/software/required/SRPMS/pyGlobus-cvs-5.src.rpm
Notice that I've moved the rat and vic rpms out of the AccessGrid
versioned path and into the required software path.
If you want to get these via the web:
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/required/RPMS/AccessGrid-rat-4.2.22-2.i386.rpm
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/required/RPMS/AccessGrid-vic-2.8ucl1.1.3-3.i386.rpm
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/required/RPMS/pyGlobus-cvs-5.i386.rpm
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/required/windows/WinGlobus-2.0-7.exe
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/required/SRPMS/AccessGrid-rat-4.2.22-2.src.rpm
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/required/SRPMS/AccessGrid-vic-2.8ucl1.1.3-3.src.rpm
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/required/SRPMS/pyGlobus-cvs-5.src.rpm
