IDL & WSDL
Ivan R. Judson
judson at mcs.anl.gov
Thu May 8 15:46:44 CDT 2003
This is pretty cool looking, but definitely not something we need to deal
with before 2.0 is out the door. We could also chat with Keith/Josh about
tools they have experience with --
How's the cert mgmt stuff going?
--Ivan
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov
> [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
> Sent: Wednesday, May 07, 2003 10:29 AM
> To: ag-dev at mcs.anl.gov
> Subject: IDL & WSDL
> My curiosity got the best of me and I had to try this.
> The following IDL:
> module AG
> enum userType { person, node };
> struct user {
> string name;
> userType type;
> struct entryReturn {
> boolean success;
> long privateId;
> sequence<user> users;
> interface VenueServer
> entryReturn Enter(in string profile);
> translates to the WSDL at the end of this message.
> I find the IDL formulation of that made-up interface quite
> readable and
> reasonably self-documenting.
> --bob
> <?xml version="1.0"?>
> <!-- root element definitions defines set of related services -->
> <definitions name="vc.wsdl"
> targetNamespace="vc"
> xmlns:wsdlns ="vc"
> xmlns:typens ="vc"
> xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
> xmlns:xsd ="http://www.w3.org/2001/XMLSchema"
> xmlns ="http://schemas.xmlsoap.org/wsdl/"
> <!-- types encapsulates schema types; here using xsd --> <types>
> <!-- all type declarations are in a chunk of xsd -->
> <schema targetNamespace="vc"
> xmlns ="http://www.w3.org/2001/XMLSchema"
> elementFormDefault = "qualified"
> xmlns:soap ="http://schemas.xmlsoap.org/wsdl/soap/"
> xmlns:soapenc ="http://schemas.xmlsoap.org/soap/encoding/"
> xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
> <!-- define enum AG_userType-->
> <xsd:simpleType name="AG_userType">
> <xsd:restriction base="xsd:string">
> <xsd:enumeration value ="person" />
> <xsd:enumeration value ="node" />
> </xsd:restriction>
> </xsd:simpleType>
> <!-- define struct AG_user-->
> <complexType name="AG_user">
> <xsd:sequence>
> <xsd:element name="name" minOccurs="1" maxOccurs="1"
> type="xsd:string" />
> <xsd:element name="type" minOccurs="1" maxOccurs="1"
> type="typens:AG_userType" />
> </xsd:sequence>
> </complexType>
> <!-- define struct AG_entryReturn-->
> <complexType name="AG_entryReturn">
> <xsd:sequence>
> <xsd:element name="success" minOccurs="1" maxOccurs="1"
> type="xsd:boolean" />
> <xsd:element name="privateId" minOccurs="1" maxOccurs="1"
> type="xsd:long" />
> <xsd:element name="users" minOccurs="1" maxOccurs="1"
> type="typens:SequenceOf_AG_user" />
> </xsd:sequence>
> </complexType>
> <complexType name="SequenceOf_AG_user">
> <xsd:complexContent>
> <xsd:restriction base="soapenc:Array">
> <xsd:sequence>
> <xsd:element type="typens:AG_user" name="item"
> minOccurs="0"/>
> </xsd:sequence>
> <xsd:attribute ref="soapenc:arrayType"
> wsdl:arrayType="typens:AG_user[]"/>
> </xsd:restriction>
> </xsd:complexContent>
> </complexType>
> </schema>
> </types>
> <!-- define operation: AG_VenueServer_Enter-->
> <message name="AG_VenueServer_EnterRequest" >
> <part name="profile" type="xsd:string" />
> </message>
> <message name="AG_VenueServer_EnterResponse" >
> <part name="return" type="typens:AG_entryReturn" /> </message>
> <portType name="AG_VenueServerPortType">
> <operation name="AG_VenueServer_Enter">
> <input message="wsdlns:AG_VenueServer_EnterRequest" />
> <output message="wsdlns:AG_VenueServer_EnterResponse" />
> </operation>
> </portType>
> <binding name="AG_VenueServerBinding"
> type="wsdlns:AG_VenueServerPortType">
> <soap:binding style="rpc"
> transport="http://schemas.xmlsoap.org/soap/http" />
> <operation name="AG_VenueServer_Enter" >
> <soap:operation soapAction="AG_VenueServer_Enter" />
> <input>
> <soap:body use="encoded" namespace="vc"
> encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" />
> </input>
> <output>
> </output>
> <fault>
> </fault>
> </operation>
> </binding>
> <service name="AG_VenueServerService" >
> <port name="AG_VenueServerPort"
> binding="wsdlns:AG_VenueServerBinding" >
> <soap:address location="foo" />
> </port>
> </service>
> </definitions>
