App stuff
Ivan R. Judson
judson at mcs.anl.gov
Thu Mar 13 09:32:58 CST 2003
Rather than block on this much longer since I think we want it soon; I'm
sending yo u my issues to think about. Then you can respond perhaps with
some proposed solution. I can propose solutions too, however they're less
likely to suit your taste than one you produce :-).
First, simple thing: I think the Application Service wants to be an
Application Factory. That's the pattern it implements. It's more clear to
developers that way and it's not user exposed. It's to our advantage to
leverage the clarity of common naming I think.
Second, I'd like to minimize the design to keep things simple. The web
service interface should only have 4 methods (and two of those I'd like to
consider dropping) for join/leave (the two I don't think we _need_, although
they are convenient), and get/set data. I don't think we need to support
more complex interactions until we are asked to do so. Let's see what
people build first.
Third, I'd like to encapsulate the client stuff in a class so the developer
doesn't have to deal with the guts. It also affords us an opportunity to
keep our decision about whether the app is a venueclient or not behind a
clean interface so we can change our minds if we choose too.
Fourth, I think I want to change our minds now on the venue client issue.
I'm not adamant about it, but I think it's not advantageous to make all
applications venue clients. They really aren't in a lot of ways and it feels
like it muddy's our design to do that.
Anyhow, those are my four main concerns. If we can blow through this today
and get a timeline for merging the branch that'd be great. I'm guessing it
won't be for tomorrow, but perhaps it could be.
Finally, We've gone back and forth on implementation vs interface, and I
think it's clear (but easily forgotten) that we're building implementation.
We're only building interface where it's missing. We're really relying on
pyGlobus (and later pyGridWare) for interface. That being said, I don't
think we need to explicitly build interface objects for all our
implementation objects where they are only passing through with no added
value. We're going to have to go back and remove that later, so have it in
there now?
Ok, enough. I'll stop. In a half an hour, perhaps you'll have time to bring
some responses to our 10am. That'd be great :-).
--Ivan
