update
Ti Leggett
leggett at mcs.anl.gov
Wed Mar 12 10:43:41 CST 2003
It does mean that, though without some build instructions, they'll be
hosed.
The globus_setup stuff is in WinGlobus/globus_setup and there's some
things in there that need to be built prior to packaging as well.
On Wed, 2003-03-12 at 10:39, Ivan R. Judson wrote:
> One clarificatin question:
> Does this mean someone can attempt to check out winglobus from cvs and build
> a working GT2.0 windows globus?
> Does it include the accessory python that we've been packaging with
> winglobus?
> If not, where is that python living?
> --Ivan
> > -----Original Message-----
> > From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
> > Sent: Wednesday, March 12, 2003 10:38 AM
> > To: 'Ti Leggett'; 'AG Dev'
> > Subject: RE: update
> > Ti,
> > Good work. I wouldn't worry too much about the one click to
> > build the installer problem. We'll get there. For now
> > manually building them is fine, as long as it's clear enough
> > for someone to get through it.
> > We can poke at the big green build button later :-)
> > --Ivan
> > > From: owner-ag-dev at mcs.anl.gov
> > > [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Ti Leggett
> > > Sent: Wednesday, March 12, 2003 10:22 AM
> > > To: AG Dev
> > > Subject: Re: update
> > > Alrighty,
> > > - I fixed the wgpi bailing problem. It was a matter of cvs
> > > mangling binary files. I've since added *.exe and *.dll to
> > > the list of files to be added as binary to the cvswrappers
> > > file in CVSROOT.
> > > - The installer now creates a registry key that points to a
> > > file and not a directory
> > > - The installer postinstall script checks for above file and
> > > creates one if it doesn't exist. This is so the
> > > globus_setup.py doesn't appear to be broken when someone goes
> > > to run it the first time.
> > > - Commited my vic project file fixes so that should build fine
> > > TODO
> > > I'm trying to come up with an installer prebuild script for
> > > both ag and globus that will build all the necessary VC
> > > components so that people shouldn't have to worry too much
> > > about what and in what order things need to be compiled.
> > > I need to work on some other things the rest of the day, but
> > > I should be able to jump back on this tomorrow or later on tonight.
> > > On Tue, 2003-03-11 at 21:40, Ti Leggett wrote:
> > > > Here's what I got accomplished tonight:
> > > > WinGlobus is now in cvs. Module name: WinGlobus
> > > > It should have all the WinGlobus stuff cleaned and ready to
> > > build as
> > > > well as the globus setup py files and the iss files. To build
> > > > WinGlobus you have to first clean both the threaded and non
> > > threaded
> > > > lib solutions, delete all the globus*.lib in /lib. Then you
> > > build the
> > > > non threaded solution, then you rebuild gssapi. Then you build the
> > > > threaded solution.
> > > > In order to make a windows installer you'll need pyglobus
> > and pydns.
> > > > NOTE: after rebuilding wgpi now dies horribly so there
> > will be more
> > > > debugging tomorrow.
> > > > I also fixed the generate a certificate certreq.cmd and
> > ssleay.conf
> > > > files so they actually work.
> > > > I also changed everything to use AppDate\globus instead of .globus
> > > > I also cleaned up the Prebuild.cmd script so it's a bit easier to
> > > > change to build installers on others machines.
> > > > I also added version numbers to the installer exectuable.
> > > > On the AG side of things.
> > > > - I cleaned up and fixed the makeServiceZips.py file
> > > > - Cleaned up the Prebuild.cmd and iss files
> > > > - Rebuilt ag-rat with VS.NET thanks to Ivan's fixes
> > > > - Rebuilt ag-vic with VS.NET thanks to Ivan's fixes and also fixed
> > > > some project depenedencies which I haven't commited yet.
> > ag-vic was
> > > > also built without the intel jpeg library though to really
> > > fix we need
> > > > to remove some files out of CVS.
> > > > - Made it so py files are copied to pyw files and pointed
> > the icons
> > > > and shortcuts at those instead
> > > > I probably did a few other things but can't remember right now.
> > > > I'm going home.
