Datastore client API
Robert Olson
olson at mcs.anl.gov
Fri Jul 25 17:30:01 CDT 2003
I have committed AccessGrid.DataStoreClient and
AccessGrid.DataStoreClientUI. These implement a simple high-level interface
to a Venue datastore.
Within DataStoreClient is a ftp-ish command line client interface to the
datastore. While useful on its own, it provides a set of examples of the
interface to the datastore. To try it out, just run DataStoreClient.py at
the command line
Notably, this module introduces methods that reutrn filehandles for reading
from and writing to the venue datastore. The current implementation does
this by simply downloading before read, and uploading after write. However,
they should simplify the use of a venue datastore when those are the
natural operations (for instance, with them one could pickle directly to
and from venue datafiles).
I've committed an initial cut at documentation on this; a PDF of same is
attached.
Tom - can you have a look at this and see what it'd take to move the
powerpoint code to using it? I think it should simplify it quite a bit.
The missing piece in all of this is getting the URL to the venue passed to
client apps that are invoked via the venue client. One way would be to pass
this information in an environment variable, but it's unclear if wxExecute
or wxShell pass environment variables through. When we're not executing
with DDE we should be able to use one of the os.spawn variants to do this tho.
--bob
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20030725/38747117/attachment.pdf>
