Node Setup Wizard
Susanne Lefvert
lefvert at mcs.anl.gov
Wed Jul 23 14:38:29 CDT 2003
I have started working on the node setup wizard and would like to
give you an update so I can get comments and ideas if I missed something.
Before starting the wizard:
Start service managers on all node machines.
Run SetUpVideo.py on video machine to find installed capture cards.
The wizard:
--- Video Capture
* Let user specify video capture machine name and which port is used by
the service manager on that machine. (Verify that the service manager is
running on that machine)
* Show what capture cards are installed on the video capture machine and
let the user select which port each card should use.
--- Video Display
* Let user specify video diplay machine name and which port is used by the
--- Audio
* Let user specify audio machine name and which port is used by the
running)
* Save this configuration with an option to use it as default. If it is
default, the venue client will use this configuration when it is run in
personal node mode.
/Susanne
