VenueClient restructure
Robert Olson
olson at mcs.anl.gov
Wed Jul 2 12:49:23 CDT 2003
At 09:03 AM 6/24/2003 -0500, Susanne Lefvert wrote:
>I've been thinking about inheritance and not inheritance between
>bin.VenueClient and AccessGrid.VenueClient and would like to argue for
>inheritance :) If we remove inheritance, both classes will have to have an
>instance of the other class.
That's not an argument for using inheritance..
>Events will be received by AccessGrid.VenueClient, which
>have to call bin.VenueClient and a button event will be received in
>bin.VenueClient that will call AccessGrid.VenueClient. If we remove
>inheritance, both classes must have callback methods for the other
>class to use.
That's fine; the same communication is happening in each case; it is a big
win to make explicit what is actually happening.
> If we then add a new client (non ui based or something
>else), it will have to implement all callback methods instead of just
>overriding necessary methods from AccessGrid.VenueClient.
Right. Again, making the communication explicit instead of implicit in the
inheritance is a win (I have a hard time understanding the current
structure because I have to keep going back thru to see what's inherited, etc).
--bob
