[globus-python] Latest pyGlobus
Robert Olson
olson at mcs.anl.gov
Fri Jan 31 13:44:19 CST 2003
here it is:
import string
import sys
from os.path import normpath
import os
GLOBUS_LOCATION = os.getenv("GLOBUS_LOCATION")
dep = sys.argv[-1]
libs = ["globus_common_win32dbgthr",
"globus_io_win32dbgthr",
"globus_oldgaa",
"globus_sslutils",
"globus_opensslmodule",
"globus_gss_assist",
"globus_gssapi",
"libeay32",
"ssleay32",
"globus_gass_copy_win32dbgthr",
"globus_gass_transfer_win32dbgthr",
"globus_gridftp_client_win32dbgthr",
"globus_gridftp_control_win32dbgthr",
winlibs = ["user32",
"advapi32",
"gdi32",
"ws2_32",
"mswsock"]
libs_str = string.join(map(lambda a: "-l%s" % (a), libs))
winlibs_str = string.join(map(lambda a: "-l%s" % (a), winlibs))
libdirs = ["%s/lib" % (GLOBUS_LOCATION) ]
incdirs = ["%s/include/threaded" % (GLOBUS_LOCATION),
"%s/include" % (GLOBUS_LOCATION)]
libdirs_str = string.join(map(lambda a: "-L%s" % (normpath(a)), libdirs))
incdirs_str = string.join(map(lambda a: "-I%s" % (normpath(a)), incdirs))
allowed_deps = ["globus_common",
"globus_ftp_client",
"globus_ftp_control",
"globus_gass_copy",
"globus_gass_transfer",
"globus_io"]
if dep not in allowed_deps:
print "ERROR: this dependency not allowed"
sys.exit(1)
print "GLOBUS_CFLAGS = "
print "GLOBUS_INCLUDES = ", incdirs_str
print "GLOBUS_LIBS = ", winlibs_str
print "GLOBUS_PKG_LIBS = ", libs_str
print "GLOBUS_LDFLAGS = ", libdirs_str
At 11:36 AM 1/31/2003 -0800, Keith Jackson (DSD staff) wrote:
>That sounds reasonable. It should work for the IBM AIX version that
>doesn't have GPT also. Want to let me take a look at the hacked
>globus-makefile-header?
>thx,
>--keith
>Robert Olson wrote:
>>Actually, I'm using your setup.py with a hacked globus-makeifle-whatever
>>script that just says what happens to be needed, with a mod to the
>>setup.py to find globus-makefile-header.py if it's there. works great..
>>At 06:18 PM 1/30/2003 -0800, Keith Jackson (DSD staff) wrote:
>>>Ivan,
>>>Bob Olson and folks have a setup.py file that works on windows. Maybe
>>>now is a good time to begin the discussion about how we integrate that
>>>into the main release. It may be as simple as just checking if we're on
>>>win32 and using a hard coded set of libraries and includes.
>>>Bob, do you want to comment on what the state of your setup.py file is?
>>>Do you think we will be able to integrate it in?
>>>thx,
>>>--keith
>>>Ivan R. Judson wrote:
>>>>I was a bit dismayed to read that the latest pyglobus setup.py is
>>>>looking to
>>>>see if GPT is installed, and failing if not. GPT isn't supported on windows
>>>>(as far as I know); is there a way to get the latest pyGlobus installed on
>>>>windows (sans GPT)?
>>>>--Ivan
>>>Keith R. Jackson KRJackson at lbl.gov
>>>Secure Grid Technologies Group (510) 486-4401
>>>Lawrence Berkeley National Laboratory http://www-itg.lbl.gov/~kjackson/
