allowing other identities to connect
Robert Olson
olson at mcs.anl.gov
Thu Jan 30 18:57:47 CST 2003
the clients need to be updated as well (authentication goes both ways).
--bob
At 06:26 PM 1/30/2003 -0600, Ivan R. Judson wrote:
>I successfully ran the venuemanagement.py, and deleted two duplicate venues,
>but I can't add one (I get the following authorization failure):
>creating proxy on
>https://vv2.mcs.anl.gov:11006/Venues/000000f3119d4aa4008c00dd
>000b0037b68
>Traceback (most recent call last):
> File "C:\software\AccessGrid\bin\VenueManagement.py", line 345, in
>OpenAddVenu
>eDialog
> addVenueDialog = AddVenueFrame(self, -1, "", venueList =
>self.venuesList)
> File "C:\software\AccessGrid\bin\VenueManagement.py", line 890, in
>__init__
> self.Ok()
> File "C:\software\AccessGrid\bin\VenueManagement.py", line 905, in Ok
> self.parent.InsertVenue(data, exitsList)
> File "C:\software\AccessGrid\bin\VenueManagement.py", line 379, in
>InsertVenue
> newUri = self.application.AddVenue(data, exitsList)
> File "C:\software\AccessGrid\bin\VenueManagement.py", line 97, in AddVenue
> Client.Handle(uri).get_proxy().SetConnections(exitsList)
> File "C:\software\AccessGrid\AccessGrid\hosting\pyGlobus\AGGSISOAP.py",
>line 3
>644, in __r_call
> self.__hd, self.__ma)
>line 3
>562, in __call
> config = self.config)
> File "C:\Software\AccessGrid\AccessGrid\hosting\pyGlobus\Client.py", line
>139,
> in call
> r.endheaders()
> File "C:\Software\Python22\lib\httplib.py", line 695, in endheaders
> self._send_output()
> File "C:\Software\Python22\lib\httplib.py", line 581, in _send_output
> self.send(msg)
> File "C:\Software\Python22\lib\httplib.py", line 548, in send
> self.connect()
> File "C:\Software\globus\python\pyGlobus\io.py", line 1073, in connect
> self.sock.connect(self.host, self.port, self.io_attr)
> File "C:\Software\globus\python\pyGlobus\io.py", line 658, in connect
> raise ex
>pyGlobus.io.GSITCPSocketException: an authentication operation failed
> > -----Original Message-----
> > From: owner-ag-dev at mcs.anl.gov
> > [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Thomas Uram
> > Sent: Thursday, January 30, 2003 5:21 PM
> > To: Robert Olson
> > Cc: ag-dev at mcs.anl.gov
> > Subject: Re: allowing other identities to connect
> > I made this trivial change in VenueServer.py and it works
> > (tested with
> > Susanne). I committed the change, and started a server at
> > https://vv2:11006/VenueServer (if that looks like a
> > non-standard port,
> > that's because it's supposed to).
> > I'll make this change on the NodeManagement services too.
> > Tom
> > Robert Olson wrote:
> > > The default authorization mode is
> > > GLOBUS_IO_SECURE_AUTHORIZATION_MODE_SELF, which means to only allow
> > > connections from processes with the same identity.
> > > You can create an authorization callback on either a Client or a
> > > Server to allow the application to decide. Returning 1 allows the
> > > connection to complete, returning 0 makes it fail.
> > > First the client:
> > > import Client
> > > import os
> > > def cb(server, g_handle, remote_user, context):
> > > print "got callback for user ", remote_user
> > > return 1
> > > h = Client.Handle('https://localhost:8000/100', authCallback = cb)
> > > ret = None
> > > try:
> > > ret = h.get_proxy().method(3)
> > > except Client.FaultType, f:
> > > print "call raised fault ", f, dir(f)
> > > print "faultcode='%s'" % (f.faultcode)
> > > print "string='%s'" % ( f.faultstring)
> > > else:
> > > print "Got '%s' '%s' from method" % (ret, map(lambda x: str(x),
> > > ret))
> > > And the server:
> > > [[Other code elided]]
> > > print "Server gets identity ", remote_user
> > > return 1
> > > if __name__ == "__main__":
> > > server = Server.Server(8000, auth_callback = cb)
> > > s = server.create_service(C)
> > > print "Have %s %s" % (s, s.get_handle())
