allowing other identities to connect
Robert Olson
olson at mcs.anl.gov
Wed Jan 29 13:09:41 CST 2003
The default authorization mode is GLOBUS_IO_SECURE_AUTHORIZATION_MODE_SELF,
which means to only allow connections from processes with the same identity.
You can create an authorization callback on either a Client or a Server to
allow the application to decide. Returning 1 allows the connection to
complete, returning 0 makes it fail.
First the client:
import Client
import os
def cb(server, g_handle, remote_user, context):
print "got callback for user ", remote_user
return 1
h = Client.Handle('https://localhost:8000/100', authCallback = cb)
ret = None
try:
ret = h.get_proxy().method(3)
except Client.FaultType, f:
print "call raised fault ", f, dir(f)
print "faultcode='%s'" % (f.faultcode)
print "string='%s'" % ( f.faultstring)
else:
print "Got '%s' '%s' from method" % (ret, map(lambda x: str(x), ret))
And the server:
[[Other code elided]]
print "Server gets identity ", remote_user
return 1
if __name__ == "__main__":
server = Server.Server(8000, auth_callback = cb)
s = server.create_service(C)
print "Have %s %s" % (s, s.get_handle())
