ServiceObject.IsValid() method
Ivan R. Judson
judson at mcs.anl.gov
Mon Feb 10 15:56:15 CST 2003
Excellent, this will tie another loose end on the server startup stuff.
--Ivan
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Monday, February 10, 2003 3:39 PM
> To: judson at mcs.anl.gov; judson at mcs.anl.gov; 'AG Dev'
> Subject: RE: ServiceObject.IsValid() method
> At 03:33 PM 2/10/2003 -0600, Ivan R. Judson wrote:
> >Another thing that comes to mind that would make the venue server
> >startup easier would be some call (perhaps via the hosting
> environment)
> >to return the authorization information of the user running the
> >process.
> Ah, right. that's in there somewhere, lemme hunt..
> Now in hosting.pyGlobus.utilities:
> def GetDefaultCredential():
> gss_cred = pyGlobus.security.get_default_user_credenial()
> if gss_cred is None:
> return None
> else:
> return gss_cred.get_name()
> will show up when my branch gets merged. Note that if there
> is no proxy
> this will return None.
