ServiceObject.IsValid() method
Ivan R. Judson
judson at mcs.anl.gov
Sat Feb 8 14:50:22 CST 2003
Yeah, I don't expect this is one of those 'use it all the time' things, but
for example to verify that a venue url actually maps to a venue the first
time would make the code a lot less twisty and turny.
I can't think of any other cases, actually.
--Ivan
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Saturday, February 08, 2003 2:33 PM
> To: judson at mcs.anl.gov; 'AG Dev'
> Subject: RE: ServiceObject.IsValid() method
> Hm. The price you pay is an expensive roundtrip to verify if
> you have the
> object you're looking for, rather than just handling the
> exception when you
> have it wrong.
> --bob
> At 01:55 PM 2/8/2003 -0600, Ivan R. Judson wrote:
> >I don't know. The behavior I'm trying to avoid is that a
> client object
> >(result of ...get_proxy() isn't really anything until a call
> is made,
> >but if that call fails your down the error handling path -- you'd
> >really like to know if the handle is valid ahead of time in some
> >cases...
> >Does that make it any more clear? The words that come to
> mind are "you
> >want to know you have a valid proxy object before you use
> it", but I'm
> >not sure that helps make it more clear :-)
> >--Ivan
> > > Sent: Saturday, February 08, 2003 1:38 PM
> > > Subject: Re: ServiceObject.IsValid() method
> > > is that doing the same thing as isinstance(obj, ServiceObject) ?
> > > At 01:32 PM 2/8/2003 -0600, Ivan R. Judson wrote:
> > > >I propose we add amethod IsValid() to the service object
> > > that returns
> > > >true. Then you can verify that your handle is good *before*
> > > you try to
> > > >use it. This makes it significantly easier to handle cases
> > > like venue
> > > >entering...
> > > >Thoughts?
