FW: [AVT] I-D ACTION:draft-ietf-avt-text-red-00.txt
Ivan R. Judson
judson at mcs.anl.gov
Fri Dec 19 08:36:54 CST 2003
This is interesting as a way to think about text.
--Ivan
> -----Original Message-----
> From: avt-admin at ietf.org [mailto:avt-admin at ietf.org] On
> Behalf Of Internet-Drafts at ietf.org
> Sent: Thursday, December 18, 2003 2:29 PM
> To: IETF-Announce:
> Cc: avt at ietf.org
> Subject: [AVT] I-D ACTION:draft-ietf-avt-text-red-00.txt
> A New Internet-Draft is available from the on-line
> Internet-Drafts directories. This draft is a work item of the
> Audio/Video Transport Working Group of the IETF.
> Title : Registration of the text/red MIME Sub-Type
> Author(s) : P. Jones
> Filename : draft-ietf-avt-text-red-00.txt
> Pages : 5
> Date : 2003-12-18
> This document defines the text/red MIME sub-type. The actual RTP
> packetization for this MIME type is specified in RFC 2198.
> A URL for this Internet-Draft is:
> http://www.ietf.org/internet-drafts/draft-ietf-avt-text-red-00
.txt
To remove yourself from the IETF Announcement list, send a message to
ietf-announce-request with the word unsubscribe in the body of the message.
Internet-Drafts are also available by anonymous FTP. Login with the username
"anonymous" and a password of your e-mail address. After logging in, type
"cd internet-drafts" and then
"get draft-ietf-avt-text-red-00.txt".
A list of Internet-Drafts directories can be found in
http://www.ietf.org/shadow.html
or ftp://ftp.ietf.org/ietf/1shadow-sites.txt
Internet-Drafts can also be obtained by e-mail.
Send a message to:
mailserv at ietf.org.
In the body type:
"FILE /internet-drafts/draft-ietf-avt-text-red-00.txt".
NOTE: The mail server at ietf.org can return the document in
MIME-encoded form by using the "mpack" utility. To use this
feature, insert the command "ENCODING mime" before the "FILE"
command. To decode the response(s), you will need "munpack" or
a MIME-compliant mail reader. Different MIME-compliant mail readers
exhibit different behavior, especially when dealing with
"multipart" MIME messages (i.e. documents which have been split
up into multiple messages), so check your local documentation on
how to manipulate these messages.
Below is the data which will enable a MIME compliant mail reader
implementation to automatically retrieve the ASCII version of the
Internet-Draft.
